Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Tennessee Radio Discussion Forum
Tennessee Radio Discussion Forum Forum for discussing Radio Information in the State of Tennessee.
Old 12-31-2008, 08:04 PM
DonnieDog's Avatar
Default Sullivan County
Is the Sullivan County Trunking System APCO 25?? RR shows that some of it is but ive been told that its not. Thanks for any help given
RS Pro-197
Yaesu FT-60R
Sometimes things are better left unsaid.............
Old 01-01-2009, 12:45 PM
n4yek's Avatar
It is a Type II system with analog talkgroups. But, if they decided to use P25 all they would have to do is upgrade the radios.
Danny Harp Jr.
HAM Radio Operator: N4YEK
Old 01-04-2009, 12:36 PM
kf4uel's Avatar
Send a message via ICQ to kf4uel Send a message via MSN to kf4uel Send a message via Yahoo to kf4uel
Default Sullivan County SO
Can anybody figure out the Sheriff's office unit number structure, Kingsport and Bristol are decently consistent.
Heres the last couple days
Kingsport PD 148
Kingsport PD 149
Kingsport PD 153
Kingsport PD 162
Bristol PD 310
Bristol PD 334
Bristol PD 364
Bristol PD 378
Bristol PD 382
Bristol PD 415
Bristol PD 429
Bristol PD 432
Bristol PD 435
Bristol PD 436
Bristol PD 440
Bristol PD 443
Bristol PD 447
Bristol PD 448
Bristol PD 450
Bristol PD 454
Sullivan County SO 1741
Sullivan County SO 1751
Sullivan County SO 2585
Sullivan County SO 2869
Sullivan County SO 2940
Kingsport PD 3101
Kingsport PD 3102
Kingsport PD 3103
Kingsport PD 3104
Kingsport PD 3105
Kingsport PD 3106
Kingsport PD 3107
Kingsport PD 3155
Kingsport PD 3204
Kingsport PD 3252
Kingsport PD 3253
Kingsport PD 3255
Sullivan County SO 3540
Sullivan County SO 4017
Sullivan County SO 4106
Sullivan County SO 4124
Sullivan County SO 4126
Sullivan County SO 4254
Sullivan County SO 4403
Sullivan County SO 4487
Sullivan County SO 4685
Sullivan County SO 4748
Sullivan County SO 4750
Sullivan County SO 4773
Sullivan County SO 4866
Sullivan County SO 4905
Sullivan County SO 5023
Kingsport PD Station C
Welmont Hospital Welmont 1
Mike Hale - KF4UEL
Southwest Virginia LIVE SCANNER
http://scannerfood.com
Old 02-02-2009, 01:08 AM
I am a Auxiliary/Reserve officer for Bristol, TN we use our badge numbers as our radio numbers, the lower the number the longer you have been there. Kingsport is a little different your radio number changes almost everyday....you have 4 digits i believe the first one is the shift you work in for example if you work 3rds the first digit is 3. the second number is the zone u work so if u work zone 2 it would be a 2. and the last to is the radio number you have. so if i radio 23 my unit number would 3223..i hope that makes since.
Old 02-02-2009, 01:20 AM
We just got our radios upgraded from the old LCS and LTS 2000 Motorola 800mhz radios to the new XTS 2500s and XTL 2500 mobiles. It was a part of the rebanding from Sprint/Nextel I have no idea if we are a Type II or Astro Digital now.
Old 02-06-2009, 11:41 AM
kf4uel's Avatar
Does County's (deputies) unit numbers' sometimes mirror those used by KPD and BPD
Im hearing 400 series units (403, 463) respond to kingsport addresses on the county tg (49264) talk about confusing, Im guessing a county unit, with a 400 unit number serving a paper on a kingsport address? How off am i
Mike Hale - KF4UEL
Old 02-10-2009, 01:51 PM
You may be picking up Vol. Fire Dept. I am also a vol. firefighter in sullivan co. our Dept. uses 400 numbers you may be hearing Engine 403 or some other fire agency in sullivan co.
Old 02-17-2009, 08:36 PM
kf4uel's Avatar
Default Re:
Still working on Sullivan County, the fire/ems should be good I still need to revamp the SO and KPD ones to remove the dupes.. thanks for all the feedback, I think its a combination of abbreviated ids and county and pd having same resepctive identical unit ids, but ill figure it out soon enough
almost 1700 area Unit Numbers
check em out
http://scannerfood.com/files/Public%...neBook2009.xls
Mike Hale - KF4UEL
Old 02-25-2009, 11:51 AM
CAPTLPOL1's Avatar
What about the constables?
Always off topic
Old 02-25-2009, 09:19 PM
kf4uel's Avatar
Constable 131
Constable 132
Constable 135
Constable 139
Constable 140
Constable 143
Constable 147
Constable 149
Ive updated Sullivan County a little more, also got county and state names beside the frequencies ...see the previous mentioned .xls link above
Mike Hale - KF4UEL
Similar Threads
Programming Scanner Cable Git-R-Done General Scanning Forum 21 10-03-2008 02:26 AM
North Texas Skip 09/07 mbstone99 Skip / Tropospheric Ducting Forum 0 09-07-2008 08:31 PM
Hocking County 911 Mess... SLWilson Ohio Radio Discussion Forum 3 02-24-2008 05:44 PM
113 new feed links added to my website jasonpeoria911 Streaming / Broadcasting / Audio Recording 4 11-29-2007 04:08 PM
Galveston talkgroups leawoodcops Texas Radio Discussion Forum 5 06-25-2007 05:39 PM
