Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Tennessee Radio Discussion Forum
Tennessee Radio Discussion Forum Forum for discussing Radio Information in the State of Tennessee.
  #861 (permalink)
Old 08-06-2012, 5:39 PM
Curious as to what is the latest/greatest radio to monitor the Memphis/Shelby County system? Last radio I used was the BC-396T. Not a bad radio but the audio left a lot to be desired. The adjustment procedure was a nightmare. I also found that mine required a VERY strong signal to sound decent. In East Memphis, signals were very weak. I tried a variety of antennas.
I'm wonder about the new XT, the PSR-500 and even the Uniden Home Patrol.
Thanks for the input and your patience.
  #862 (permalink)
Old 08-08-2012, 9:32 AM
I am using a PSR 500 and love it.
  #863 (permalink)
Old 08-08-2012, 10:30 PM
Thanks for the answer. I appreciate it. I will read the applicable reviews. Any cons? Can you compare it to a BC-396T by chance?
Thanks much.
  #864 (permalink)
Old 08-08-2012, 11:35 PM
Try RS pro 106, or maybe not.
  #865 (permalink)
Old 12-21-2012, 5:22 PM
Got my hands on PRO-106. Better for listening to Memphis area systems vs. the Uniden 396T. P25 audio is clearer and the sensitivity is much improved. I can't hear the FedEx systems at the airport or Desoto County on the 396T. They come in fine with the 106 and stock antenna. I was using an enhanced 800 MHz antenna on the 396T. I'm in the Poplar/Perkins area. Curious what others are seeing with the PRO-106. A little tough learning curve but I'm getting there.
  #866 (permalink)
Old 12-22-2012, 10:05 PM
matthewtomek's Avatar
Live Audio Admin
I bought a PSR 500 a year or so ago and noticed it receives the Memphis system much, much better than the 396T.
Matthew Tomek
Dispatcher, Memphis Fire Dept
Memphis Fire Scanner
  #867 (permalink)
Old 12-23-2012, 4:32 PM
Thanks for the comment Matthew. Are you using the Win500 software to program by chance?
  #868 (permalink)
Old 12-24-2012, 9:41 AM
I am using Win 500 and it is the only way to go with these radios. But this is just one man's opinion. The client that is with Win 500 is pretty cool too. To be able to utilize the radio and not have to be infront of it.
  #869 (permalink)
Old 12-25-2012, 10:33 PM
Live Audio Admin
I'm using it also.
Matthew Tomek
  #870 (permalink)
Old 12-29-2012, 10:39 AM
Default Question Regarding Systems/Sites
Matthew, Radio Cop, I'm trying to get some solid info on the two sites. It seems like several years ago that MPD and MFD were on system or site 1 and the hospitals were on site 2. Right now, I have my PRO-106 programmed to scan both sites with the same TGs. However, I never see a TG come up on site two for MPD, MFD. I do see the hospitals come up on Site 2. Would you mind explaining this to me. I'm now assuming that MPD, MFD, SCSO, SCFD are all on Site 1???? Some other services are on Site 2 but I'm not sure which ones other than the hospitals?
Matthew, tried to email you. I'm guessing you're like me and have an old email address in the system?
Thanks much men.
  #871 (permalink)
Old 12-29-2012, 10:44 AM
tspainiv's Avatar
Shelby Co DB Admin
You are correct. All Public Safety for both the county and city are on site 1. All other services (city, public works, hospitals, courts, jail etc) are on site 2.
Thomas - KI4OTD
Memphis & Shelby Co. Public Safety Scanner
  #872 (permalink)
Old 12-29-2012, 10:48 AM
Thomas, that is a big help. I was concerned that the sites might be connected to geographical coverage and I should run both of them. Doing so is sucking up the resources on my PRO-106. I used to listen on a 396T but haven't had it for more than a year. Just got the PRO-106 as you can see and trying to bring myself up to speed.
To clarify, the only thing I should put on Site 1 is MPD, MFD, SCSO, SCFD? I'm assuming that only includes the TGs grouped under these headings in the database?
Thanks for your patience. I appreciate it.
  #873 (permalink)
Old 12-29-2012, 11:03 AM
tspainiv's Avatar
Shelby Co DB Admin
Yes. Site 1 should be MPD, MFD, SCSO, SCFD, Millington PD. There may be some others that I can't think of right now, but if its police or fire it's site 1.
Thomas - KI4OTD
  #874 (permalink)
Old 12-31-2012, 2:26 PM
How about the radio shop TGs? And the emergency back-ups for MPD and MLGW? These are the ones on the Memphis/Shelby County system. And, have we ever heard these used before. Would be Public Safety Back-Up and MLGW Back-Up towards end of list of TGs.
Thanks Thomas
  #875 (permalink)
Old 12-31-2012, 5:10 PM
tspainiv's Avatar
Shelby Co DB Admin
Thanks Thomas
I personally haven't heard the Backup talkgroups used, but doesn't mean they aren't. They are programed in the radios so..
Thomas - KI4OTD
  #876 (permalink)
Old 12-31-2012, 6:41 PM
Live Audio Admin
Thanks Thomas
The Radio Shop TGs are on Site 2 (if I remember right).
I thought the public safety back-up TGs were on the MLGW system. not sure why they're listed on the Memphis system. I've never programmed them in my scanner.
The MLGW TGs are probably on Site 2.
Matthew Tomek
  #877 (permalink)
Old 12-31-2012, 6:48 PM
tspainiv's Avatar
Shelby Co DB Admin
Tomek you're right. MLGW backups are on site two I believe. Also, MLGW's system carries the public safety backup talkgroups.
Thomas - KI4OTD
