Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Tennessee Radio Discussion Forum
Tennessee Radio Discussion Forum Forum for discussing Radio Information in the State of Tennessee.
Old 02-01-2010, 10:17 PM
Default Highway Patrol Going Digital?
Governor in his State of the State Address tonight proposed increased driver license fees to help fund in part the implementing a digital (presumably trunking) system statewide. Governor referred to the upgrade as long overdue.
Old 02-02-2010, 6:27 PM
ropin4gold's Avatar
John,
I heard this last night also. They are getting a new statewide system but I haven't found any specifics. I work for a state agency and hope they put us on this system because ours isn't too good. Hopefully somene will chime in that knows more about it and fill us in. It would be nice to get a system like Arkansas has.
Old 02-02-2010, 6:39 PM
Since the Department of Corrections (Prisons) have upgraded to trunk systems one would assume that would be the logical choice for THP. It sure would be nice to have a statewide trunked system rather than the hodgepodge of frequencies they use now. There also trying to save about 80 existing trooper positions at the same time. I hope they find the funds to keep the troopers and upgrade the radio system. When you consider all the rural areas the THP covers, it would either have to quite a large trunk systems or they will maintain some low frequency conventional channels too.
Old 02-02-2010, 7:35 PM
Check out this thread:
Chattanooga Regional P25 System
This system is said to be the first phase of a statewide 700/800MHz P25 trunking system.
It's also in the RR database under counties like Hamilton, Bradley, Knox, etc.
BG..
ButchGone
Old 02-03-2010, 12:36 PM
milf's Avatar
Careful, I CAN hear you!
Send a message via MSN to milf Send a message via Yahoo to milf
TN is emplementing a Statewide 700/800 P-25 TRS, the first regional third of which is the TVRTRS... Second will be midstate area, then Western. This system will have links to the MSWIN, VIPER, AWIN and the slowly growing GA TRS's and quite possibly also the KY P-25 conventianl net. Vias CSSI will also have links to the growing TXWARN system, which the first phase is the regional system along the Gulf.
Admin & Mod for AR, LA, MS, and TN
Scanology, its the path to monitoring happiness!
Support your local Scanologists!
Old 02-03-2010, 12:55 PM
Send a message via MSN to slatescan
dont forget the new SC 25 VA STARS and MOWIN (currety the st louis p25 ) and the new AL p25 (look at the MSWIN thread for news on that
David
disabled scanner nut., Pro 95 96 97 106 and 18
