Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Tennessee Radio Discussion Forum
Tennessee Radio Discussion Forum Forum for discussing Radio Information in the State of Tennessee.
Old 11-14-2011, 11:56 PM
Default Washington County silent?
Perhaps I have my scanner programmed wrong but can anyone pick up anything on the Washington County system? I know most of it is encrypted now...bastards...but I get NOTHING! Help! Being P25 Trunked I just programmed in the primary control channel of 857.4625 on my BC796D which worked a couple of months ago. Thoughts?
BC796D
Old 11-15-2011, 11:46 AM
jfhtm350's Avatar
Looks like 2 sites with the same frequencies:
Johnson City & Washington County Public Safety (Project 25) Trunking System, Johnson City, Tennessee - Scanner Frequencies
You will also need to program the alternating control channel (857.21250). Some people like to program all the frequencies in to eliminate the chance of missing the control channel including me, because some of them change daily. Just by looking at the gray site, I would say that all the control channels are not listed in red and blue so program them all in the scanner or at least the alternating channel and that should get you going.
Old 11-15-2011, 8:52 PM
Thanks for the quick reply. I tried programming them all in. No joy. It used to work two months ago with just the control channel. It's probably something they changed or with my scanner setup. Can anyone else even hear Washington County on the P25 network? At least I will know it's something I need to change.
BC796D
Old 11-15-2011, 10:36 PM
jfhtm350's Avatar
Try adding 854.01250, 859.58750 and 859.68750 as a control channel.
ULS License - Public Safety/Spec Emerg, 806-821/851-866 MHz, Trunked License - WNNS431 - City of Johnson City, Tn - Frequencies Summary
those are registered but not in the RR database.
There are no 860mhz frequencies registered for whatever reason. They must have changed somewhere down the line.
If that dont fix the problem, then manually tune to one of the frequencies and see if you even hear them on there anymore. Let me know if that works for you.
Old 11-16-2011, 10:50 AM
milf's Avatar
Careful, I CAN hear you!
Send a message via MSN to milf Send a message via Yahoo to milf
OK refreqed..... almost like its rebanded but without other changes.... Will fix in db tomorrow...
Admin & Mod for AR, LA, MS, and TN
Scanology, its the path to monitoring happiness!
Support your local Scanologists!
Old 11-16-2011, 8:33 PM
Thanks again. Now I get occasional blips of static and about a half second of audio every now and then. I tried deleting the 857.2125 control channel (which is the only one it seems to want to lock onto). Then it can't find any control channel to lock onto so it just sits there scanning the programmed frequencies. When I reprogram 857.2125 back in and tell it to trunk all the scanner does is sit there blinking SCAN, locked onto the control channel, and toggling between DAT and NFM. On 858.2375 and 859.4625 it toggles LNK and NFM. Every now and then I see the display toggle to P25/NFM.
I'm wondering if I have something programmed wrong in my Trunked bank.
EDIT: Just saw @milf post. Will wait to see the changes...
BC796D
Old 11-16-2011, 8:47 PM
jfhtm350's Avatar
Do you know which one is the Control Channel? Manually tune to the frequency and listen for the control channel noise and the system info should come up on the screen.
Pro-106 / Pro-197
Old 11-16-2011, 9:03 PM
jfhtm350's Avatar
If you cant find it, tune to these and see if one of these are the control channel.
854.01250
856.21250
856.23750
856.46250
857.21250
857.23750
857.46250
858.21250
858.23750
858.46250
859.21250
859.23750
859.46250
859.58750
859.68750
These will either be voice channels or control channels.
Pro-106 / Pro-197
Old 11-16-2011, 9:05 PM
jfhtm350's Avatar
Those are the frequencies from the fcc database which shows no 860mhz frequencies. That doesnt mean that they are not on the system though. If those dont work then try the other ones from the RR database such as the 860's.
Pro-106 / Pro-197
Old 11-16-2011, 10:25 PM
I've got the Washington County P25 system pulled up right now listening to it, it seems to be on 857.2125 for CC
Old 11-17-2011, 7:00 AM
Yes- 857.2125 is the control channel since it is the one displaying DAT and NFM. Since @jcmt is able to hear it then it must be something with my BC796D setup. I'm sorry. These trunked systems seem to get more confusing and difficult to set up every time I turn my scanner on.
I have all frequencies programmed in on one bank. I put them in numerical order. I moved the CC to the first frequency slot. But that hasn't helped. I checked to see if one frequency was accidentally programmed as Priority or something. I can hear talk if I manually tune to various frequencies but when trunking it won't do anything but park on the CC. Sometimes it seems my scanner forgets it's a trunked bank and slips back into conventional. I will try reprogramming the entire bank from scratch (I've lost my computer so I can no longer program it with my PC and must use the BC796D interface).
BTW, I find the Uniden manuals to be horribly confusing and almost useless...maybe it's just me.
BC796D
Old 11-17-2011, 11:47 AM
jfhtm350's Avatar
Sounds like the t-tables are messed up or you have the wrong setting programmed in. It probably would be best to just delete that system and reprogram it, like you say, and go from there.
Pro-106 / Pro-197
Old 11-17-2011, 12:30 PM
milf's Avatar
OK hopefully got it set up right now with the new freqs.. Keep us updated guys.
Old 11-18-2011, 7:51 PM
Using the new frequencies posted by @milf (and reprogramming the whole bank) I'm getting some conversation but I seem to be missing stuff (maybe some frequencies are missing?). Or maybe it's the encryption messing it up... I programmed in the Gray frequencies which includes all of them. For the bank I have the Status Bit set to Off and the End Code is Ignore. The bank was set to a 2 second Delay. I changed that to None...
I am picking up a few conversations but it really seems like I'm missing some dialog. Sometimes it cuts off the dispatcher. Reception is better than it was. Thanks for the help! VERY appreciated! If I figure out anything else I will post back.
EDIT: The more it scans the more it sounds like it is locking onto the conversations. I think all is well. Thanks so much!
BC796D
Old 11-18-2011, 8:19 PM
jfhtm350's Avatar
Good deal.
Pro-106 / Pro-197
Old 11-28-2011, 7:05 PM
DonnieDog's Avatar
Sorry for the delay on some input. There is now an Alt CC I think 857.2125
For some of those who read my posts...........Its a hobby pal not a secret mission!!
Pro-197
BC350C - Carter County and Elizabethton Public Safety Feed
KJ4ZDF
"In Confusion There Is Opportunity"
Old 11-28-2011, 7:07 PM
DonnieDog's Avatar
Its different than 857.2125
I dont have my scanner with me. I do know its different though. Will post as soon as I can.
Pro-197
KJ4ZDF
Old 11-29-2011, 1:45 PM
milf's Avatar
Run Pro96Com on it. That will list all the info. Tower ID, Site info, ALL CC's, etc
Old 06-04-2012, 6:52 PM
Couldn't find a better place to post. Won't let me PM or email. Carter County and Elizabethton Public Safety is down.
