Odd CW string on 173.275 MHz. What's it mean?
KD7HGK
Knoxville, TN
I'm hearing a strong CW ID on 173.275 MHz approximately every 30 minutes. Decoding it with MULTIPSK, I get this:
KJH7N 9
I can't make any sense of it. I ran that frequency through the search here and only two licenses popped up: one in Macon County, TN and the other in Shelby County, TN. I think those counties would both be too far away for me to be picking it up full strength like I am. Could it be a National Park repeater CWID? I've been hearing it since yesterday morning and I haven't heard any voice traffic just the CWID. The CW sounds the same each time so I believe it's being sent via machine.
I just now heard:
KJHG HN
Either MULTIPSK isn't decoding it correctly, or a different string is being sent each time. I can't tell.
n4yek
Newport, Tennessee
if you can, record it as a .wav file and zip it up and put it on here. Will decode it by ear and let you know what it says.
KD7HGK
Knoxville, TN
I left MULTIPSK running last night and woke up to this:
N A HM K E 77O K EHT N M T N WH7M 9K EHN 7Ö KR 77Ö KJHM £N N WHG HO N WH779KR T G I K E M 79 N W M N 9T N WH779K E 7T 9KJ N 7Ö K E 779 K EHM N Ö K E 7N 9
I'll grab an audio recording of it so you can double check the translation.
ecps92
Taxachusetts
KJH779 - KNOXVILLE NEWS SENTINEL COMPANY
Cancelled Status on 08.09.2011
KJH7N 9
I just now heard:
KJHG HN
zz0468
QRT
Banned
...Either MULTIPSK isn't decoding it correctly, or a different string is being sent each time. I can't tell.
I'd put my money on bad decoding. Put up a wav file. There's a bunch of CW ops on there who could copy it by ear.
jfhtm350
New Market TN
I dont know what you all are talking about but I hear it too. It lasted about 3 seconds with a signal of 4-5 bars. I do know that the Knoxville News Sentinel makes newspapers for Atlanta, GA, already printed up and ready to go. Could they be communicating with them or some other place they may make newspapers for?
n4yek
Newport, Tennessee
Jim,
The FCC requires repeaters to identify themselves with the callsign assigned to the frequency that is being transmitted. It does this by using morse code and his program isn't decoding it properly. That is what we are discussing and it appears that the News Sentinel is the owner of the callsign, or was before it was cancelled.
KD7HGK
Knoxville, TN
Ok, I recorded it with audicity (sp?). As a .wav it's 110MB. As a .zip it's 797kb. The zip is still too large but I don't think I can cut it down anymore as the recording is only a few seconds long to begin with. How can I share it with y'all?
edit:
I trimmed it down even further by eliminating the second or two white noise at the beginning and end of the file and it's still 600+kb in size.
freqhopping
Lo Co VA/ FM19
Why not just 'read' it from what is visible in Audacity? That's why I do. One example from one of my local recordings. Much easier to post images too.
jfhtm350
New Market TN
Thanks for the explanation. I didnt know it was required to do that. Ive never heard noise on any other frequency I have programmed in without a PL or DC code. I see the morse code in the above examples.
I might download that program just to play around with it.
KD7HGK
Knoxville, TN
So it is the news sentinel. That's that expired license that was mentioned earlier. I wonder when the FCC database will be brought up to date?
jfhtm350
New Market TN
They probably just forgot to renew their license or something or just dont use it anymore. I guess they could still have the repeater there and not use it and be legal, dont know.
Would you care to tell me how you got that image you have posted. I am interested in doing what you just did. If it makes a difference in programs your using, I would prefer to just read the morse code from the pics like you have posted, instead of letting the program do it for me.
WayneH
Forums Veteran
Super Moderator
Your master site
The software is called Audacity and is freeware. When you load up a wav you'll see it in that form. It's helpful to decode DTMF also.
Also, for those that don't know...173.2000 to 173.3875 (my edges might be off slightly) is not licensed to Federal agencies and is available for FCC licensing. It will typically be water dept telemetry but there are a few newspaper companies and others (I forget the old service types) left over. I'm sure there's an FCC Part # for it someone might know.
jfhtm350
New Market TN
Oh ok. I have an audio program that will probably show the wav file like the above example, but will download audacity anyways. I have a couple questions, maybe more when I get to going.
1) Do all repeaters put out the morse code identifier, such as pub safety, businesses, federal?
2) How did you get the wav file from the scanner (the Multipsk program)? I have an audio patch cable that I can run to my sound card that I have used with IDTrackerIII if that is what you used.
I hope this works like Im figuring. That would have saved me alot of time if I had known all this awhile back.
KD7HGK
Knoxville, TN
forget multipsk. It has nothing to do with it now. Just hook up the scanner to an audio input on your computer and turn on Audicity and hit the "record" button and wait. Eventually the CW ID will pop up and you'll have what you're looking for.
jfhtm350
New Market TN
Ok thanks. Thats kind of what I was figuring but wasnt sure.
I assume I have to leave the PL or DC codes off for it to work right?
How often does the code come across? I am going to try it on the local sheriff repeater and see if I can grab it. May be lucky to even hear it since they may be talking at the time.
