Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Tennessee Radio Discussion Forum
Tennessee Radio Discussion Forum - Forum for discussing Radio Information in the State of Tennessee.
  #41 (permalink)
Old 10-26-2012, 6:50 AM
I would imagine all sites in the region will add frequencies to handle capacity from the increased number of users.
BG..
ButchGone
  #42 (permalink)
Old 11-27-2012, 9:37 PM
It's interesting, though.
They did a build out study. Seems like they should have been able to estimate load, and put enough channels in per site initially.
surfaceMount
  #43 (permalink)
Old 11-28-2012, 6:42 AM
Question
surfaceMount
Does any one know when this system might be up and running?
  #44 (permalink)
Old 11-28-2012, 9:14 AM
milf's Avatar
Careful, I CAN hear you!
First part six months to a year, with some pieces already up, complete build out and linkage to TNVRTRS etc,... several years. Oh and a clarification on the TDMA part... It will be true P-25 Phase II TDMA, not X-2, and yes the new GRE PSR-800's will do that. Not sure on the Uniden HP-1's. On the BO study, they did an estimate, but were not expecting just how big an extra load on they would be told to expect this early. (Mushroom principle lol)
APX6000XE
  #45 (permalink)
Old 11-29-2012, 6:05 AM
Question
I have a GRE PSR-800 and should be able to receive transmissions from Grundy and Rutherford counties, however, I don't know how to load these frequencies into the scanner and there is nothing to import from the RR database that I see. I would like to hear if they are doing any "testing", etc.--any suggestions on how I might do this?
  #46 (permalink)
Old 11-30-2012, 6:15 PM
So, i got my PSR800 up and running and I am trying to program the 700/800 mhz frequencies in for the troopnet trunking system from the FCC site and the scanner will not accept some of the frequencies (i.e. 799, 801, 803 and 804 mhz freq). Found out the PSR800 doesn't cover that part of the band.
Copied from manual
764.00000 − 781.996875 MHz! 3.125 kHz! FM
791.00000 − 796.996875 MHz! 3.125 kHz! FM
806.00000 − 823.987500 MHz! 12.5 kHz! FM
So, I guess I can just program the frequencies it will take and see if I hear anything.
Those frequencies are listed as mobile classification under the license, so i guess I don't really need them if I'm looking for a control channel
  #47 (permalink)
Old 11-30-2012, 6:18 PM
RonnieUSA's Avatar
Copied from manual
Did You do the firmware update?
http://www.greamerica.com/support/in...oaditemid=1042
PSR-800 - BCT15X - FreeSCAN - NooElect R820T2+ SDR - NooElect R820T2 SDR - DSDPlus Fast Lane
  #48 (permalink)
Old 11-30-2012, 8:41 PM
milf's Avatar
Originally Posted by doctree2
Will be interesting to see if they use TDMA given that the DOC and TEMA are not. Do the rigs currently on the market have both modes? Guess they could use gateways to talk to other state agencies and locals. Just curious about the radios.
To answer that radio question, yes there are HT's and Mobiles, and Consoles that can do mixed modes. Take for example the Motorola APX series, dual band at the same time, and can do both FDMA, and TDMA. So not only can you set one up to run say an TRS that uses both 700 MHz, and 800 MHZ, or an 150 MHz/700 MHz,... or an 700 TRS, and VHF conventional.
APX6000XE
  #49 (permalink)
Old 12-01-2012, 9:18 AM
Yes, THP will be using Phase 2 TDMA from the git-go on the new 3-channel towers they are installing and the TVRCS. Keep in mind though, that if another state agency like TEMA has a THP talk group programmed into their FDMA only radio and they need to talk on it or monitor then that THP talk group goes FDMA across the board.
BG...
ButchGone
  #50 (permalink)
Old 12-02-2012, 7:39 AM
Question
BG...
Do you know in what areas and when this new system will become active?
  #51 (permalink)
Old 12-02-2012, 11:20 AM
The plan is to have THP Chattanooga, Knoxville and Fall Branch districts on line first. Basically that's all of eastern TN and the southern part of the Cumberland Plateau. The TN Dept. of Safety has a website with map of the districts. But the FCC data base is showing new TDMA towers extending west toward Nashville so it's possible the I-24 corridor into Nashville could be included.
BG..
ButchGone
  #52 (permalink)
Old 12-02-2012, 11:57 AM
Based on FCC database records here's a list of the new Phase 2 TDMA towers/frequencies the Tennessee Department of Safety is getting on the air. For folks in these areas give them a listen and please let us all know when you hear a control channel on the air. Since it's 2-slot TDMA one freq is for control channel, the two other freqs can handle a total of four simultaneous transmissions at once. These sites fill in the gaps where the TVRCS in eastern Tennessee doesn't get into. THP will operate on the TVRCS where sites are available. Keep in mind THP will also operate on new VHF channel assignments in TDMA mode where the 700/800 sites don't penetrate. Those licenses should start popping up too. Their APX series mobiles and portables are dual band and will scan for the best signal whether it's VHF, 700 or 800.
Grundy County/ Hippie Town Farms; 771.25625, 771.63125, 769.71875
Sequatchie County/College Site; 769.35625, 769.78125, 770.90625
Claiborn County/Springdale; 769.33125, 770.56875, 774.58125
Cocke County/English Mnt; 770.28125, 770.80625, 769.15625
Greene County/Viking Mnt; 769.36875, 770.50625, 770.15625
Washington County/Fall Branch; 769.83125, 771.33125, 769.18125
Hawkins County/Channe 2 site; 771.03125, 771.43125, 769.90625
Sullivan County/Bays Mnt; 769.10625, 770.05625, 773.53125
Campbell County/Walnut Mnt; 773.70625, 774.40625, 770.90625
Morgan County/Frozen Head Mnt; 770.85625, 772.65625, 769.70625
Rutherford County/Tiger Hill; 770.03125, 770.30625, 769.46875
Wilson County/Franklin Road; 769.78125, 770.08125, 773.33125
Davidson County/Cane Ridge; 769.30625, 769.58125, 770.19375
Scott County/Black Creek; 769.59375, 771.13125, 770.96325
BG..
ButchGone
  #53 (permalink)
Old 12-02-2012, 5:48 PM
jfhtm350's Avatar
Where are you getting the 769.XXXXX frequencies from? I am not seeing them in the FCC database. The other 2 frequencies are shown.
  #54 (permalink)
Old 12-02-2012, 6:01 PM
If you dig a little deeper into the license info, paying closer attention to attached letters/documents, you will find a wealth of info.
BG..
ButchGone
  #55 (permalink)
Old 12-02-2012, 9:59 PM
Originally Posted by RonnieUSA View Post
Well, I thought I did, but apparently did not get the second update in. I'll update firmware and try it then.
  #56 (permalink)
Old 12-02-2012, 10:02 PM
BG..
Well, I'm in the Knoxville area and just got my PSR 800. I'm going to program them all in and see what I get anyway. You never know. I'll listen and if I get anything to report, I'll do so.
DH
  #57 (permalink)
Old 12-02-2012, 11:22 PM
Post
BG..
THANKS VERY MUCH for this extensive list. I will program the Grundy, Sequatchie, Rutherford, Wilson and Davidson County frequencies into my GRE PSR 800, which is supposed to receive the TDMA Phase Two, and see if it will receive anything. Also, on 10/17/12, "Thunderbolt" posted a link to a license application for Hoovers Gap, which is also in Rutherford Co., and that license request listed two FB2 frequencies: 769.25625 and 769.53125.
  #58 (permalink)
Old 12-04-2012, 4:36 AM
Thunderbolt's Avatar
Forums Moderator
The FCC has approved several new sites for the TroopNet radio project. These sites may come online at any time now. More information is available on the FCC Web site:
WQQB673
WQQF489
WQMY418
Roane County E911
73's
Ron
"A bank is a place where they lend you an umbrella in fair weather and ask for it back when it begins to rain." Robert Frost.
  #59 (permalink)
Old 12-05-2012, 2:24 AM
Forums Moderator
FCC license modification request for temporary command post communications.
73's
Ron
  #60 (permalink)
Old 12-05-2012, 10:06 AM
Thanks Ron. Now I'm wondering when the VHF 3-channel TDMA sites will start showing up.
BG..
ButchGone
Tags
sticky
