| Tennessee Radio Discussion Forum Forum for discussing Radio Information in the State of Tennessee. |
12-31-2012, 5:18 PM
City of Germantown P25 testing
City of Germantown is testing it's new P25, conventional 800MHz system. It's a 6 freq. system set up on conventional P25 repeaters.
Frequencies are:
852.0500 - (appears low power)
852.2125 - Gtown PD Ch 1 (Primary)
852.9375 - Gtown PD Ch 3 (Secondary/Car 2 Car)
853.4125 - Gtown Fire Primary
853.6625 - Gtown Fire Fireground
853.9125 - unknown
Again, these channel assignments are just from monitoring channel names that techs are using, none of this is confirmed.
Repeater are using a NAC of 293.
From listening to techs, it also seems they may be using XTS2500 handhelds, again, not confirmed.
01-05-2013, 6:35 PM
It appears that Gtown Fire Primary is now active. Been listening today and hearing activity. P25 signal is clearer yesterday when it sounded like a had a patch possibly.
01-05-2013, 6:50 PM
They are patching through Memphis Fire, I'm assuming for audio level testing. They did have Gtown PD patched through for a little while. The audio quality is terrible though.
01-09-2013, 9:34 PM
Still a lot of testing today. I heard them Motorola Technicians and members of the fire dept testing in several of the schools and chruches. I heard one of the techs make the comment about having completed about 45 of the 50 buildings they were going to conduct coverage checks. This was around five thirty or six pm this evening. One of the other techs said they would pick up the rest tomorrow.
01-10-2013, 10:04 PM
The new Germantown system is a conventional P-25 simulcast system with 2 tower locations - one on the east side and one on the west side of town. The system will serve both police and fire. Look for it to go live next week.
I am responsible for the system and will be happy to answer any questions you have about the system the best I can.
01-11-2013, 12:21 AM
Would you be able to confirm the frequency assignments (i.e. GPD Dispatch, GFD Dispatch etc.) to what's in the database here? Everything in the database is based off of listening and nothing is confirmed. Also, what type of radios are you guys going with? Mobiles and portables?
Thanks.
Also, PM sent.
01-11-2013, 7:59 AM
The radios are Motorola XTS2000 and XTL2500. There are also some APX7000 radios. Your frequency observations are pretty accurate except there is no 'trailer repeater' at this time.
01-11-2013, 7:52 PM
Careful, I CAN hear you!
Sorry about that, when its listed as a Temporary Repeater, thats usually a trailer towed type, or as some call them, Site On Wheels, or Mobile Site. So if its not a SOW, what kind of Temporary Repeater is it? Mobile Command Unit? (FB2T per FCC Lic, FB2T=Temporary Repeater)
Just trying to keep the data as accurate as possible.
Admin & Mod for AR, LA, MS, and TN
Scanology, its the path to monitoring happiness!
Support your local Scanologists!
01-11-2013, 8:32 PM
Milf, it's reserved for future use.
01-11-2013, 8:41 PM
The frequency will eventually used for a tactical repeater however it has not been specd or purchased yet. It will likely be part of a mobile communications vehicle but that is yet to be determined for certain. It will be low power and used on an as needed basis.
01-12-2013, 7:24 AM
TY for the response!
01-16-2013, 2:44 PM
Cutover is going on right now. Scanner feed is live.
01-16-2013, 4:13 PM
OK will switch the old freqs to back up status.
01-17-2013, 8:08 AM
Good Sigs In East Memphis
Caught them in normal operation last night for a few minutes. Good, strong signals on hand-held radio, stationary, in East Memphis, Poplar/Perkins area.
Good work guys.
