Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Tennessee Radio Discussion Forum
Tennessee Radio Discussion Forum Forum for discussing Radio Information in the State of Tennessee.
Old 01-20-2013, 3:32 PM
Default help with knox county tn sherrif trunk system
i am having trouble programming the trunk system in a bcd 996xt it worked in the 396 handheld not sure what i am doing wrong
Old 01-20-2013, 4:36 PM
i have tried the conventional and trunked freq can anyone help
Old 01-20-2013, 4:53 PM
KC9VZV's Avatar
Hey,
I need more info before I can help you. Are you programming with a computer? Are you trying to program a P25 system or what?
-Dan
73,
Dan, KC9VZV
IPN Dispatcher: ILL043
Old 01-20-2013, 5:23 PM
n4yek's Avatar
What program are you using to program it with? If it is Freescan, zip the file and upload it and maybe I can help you get it straight.
Danny Harp Jr.
HAM Radio Operator: N4YEK
Old 01-20-2013, 5:38 PM
n4yek's Avatar
If you use Freescan, try the file I created. Unzip it and load it into your scanner.
Danny Harp Jr.
Old 01-20-2013, 6:07 PM
i have unziped the file uploaded it to the scanner using freescan still no luck the file u posted looked pretty close to what i have created at a glance
Old 01-20-2013, 7:14 PM
milf's Avatar
Careful, I CAN hear you!
Send a message via MSN to milf Send a message via Yahoo to milf
Do you have all the latest software/firmware updates etc in the scanner? Make sure all those are set up. Then reload the Knox County file and see how it works. How is it doing with the other things your trying to scan? If after trying all else, manually program in the Knox County/Knoxville TRS.
Admin & Mod for AR, LA, MS, and TN
Scanology, its the path to monitoring happiness!
Support your local Scanologists!
Old 01-20-2013, 10:59 PM
jfhtm350's Avatar
Can you not get the conventional frequencies to work?
Try to program these in to see if it works:
462.98750 245 DC Rural/Metro EMS Dispatch Ch ALS
463.18750 271 DC Rural/Metro EMS Dispatch Ch BLS
They are constantly on one of those two frequencies.
Pro-106 / Pro-197
Old 01-21-2013, 5:00 PM
the conventional freqs work fine and even the p-25 system i programed for blount county works just having trouble with the knox county trunking system
the firmware version is 1.06.00 not sure if that is up to date
thanks everyone for the input i am about to pull my hair out on this one
Old 01-21-2013, 6:04 PM
scanningisfun's Avatar
Send a message via MSN to scanningisfun
I have this system programmed into my 396XT. What issues are you having?
Jacob
Old 01-21-2013, 6:07 PM
n4yek's Avatar
You have the latest version of firmware, not sure what is going on though. The file should have worked, everything is there that needs to be unless I have missed something also. If you do get it going, make sure you post the solution.
Let me ask you this, do you have the scanner connected to an outside antenna? Even then, you might be pushing the limits of the reception of the Knox County TRS.
Danny Harp Jr.
Old 01-21-2013, 6:25 PM
jfhtm350's Avatar
854.4125 is the control channel at this very moment. Check to see if its programmed in. It probably is if your using N4YEK's file. Tune to 854.4125 and see if you get the control channels info on the screen and note the signal strength.
Pro-106 / Pro-197
Old 01-21-2013, 6:30 PM
jfhtm350's Avatar
Like Danny says, the trunking system does not have the range the conventional systems in Knox Co has and I see your in Maryville. I am on the fringe of the trunked system myself and it does not come in good enough for me to monitor here although I can hear the Fire and EMS/Medcom channels fairly well. You may also have an antenna issue. You could probably drive to Knoxville with it and it will work.
Pro-106 / Pro-197
Old 01-21-2013, 6:55 PM
i also programmed it in a 396 with no problem but i am having trouble with it in a 996xt i stoped it on kpd a centrl and it it flashes over to finding control channel i also stopped it on control channel and hear nothing
Old 01-21-2013, 8:18 PM
thanks guy i have solved the problem i switched to a rubber ducky antenna and now i can receive knox county i cant believe that fixed my problem thanks for your time
Old 01-21-2013, 8:44 PM
jfhtm350's Avatar
Good deal.
Pro-106 / Pro-197
Old 01-21-2013, 9:12 PM
I really don't know what to say. If you have already verified by holding on each of the control channel frequencies, and you aren't getting any signal, I'm kinda stuck on suggestions. Make sure you have all of the CC frequencies in the scanner.
854.4125
857.2125
858.2125
859.2125
Jacob
Old 02-03-2013, 3:48 AM
hey KC9VZV
Got a few questions for you can you shoot me a PM i cant send them to you yet
Old 02-03-2013, 12:28 PM
KC9VZV's Avatar
Originally Posted by TS0918 View Post
hey KC9VZV
I tried to send you a PM but it says you have chosen to not receive PMs. If you want to PM me, that would be great otherwise you can email me at TriComFeed@gmail.com.
Sorry about that.
-Dan
Edit: I didn't realize that you said you can't send PMs. Feel free to email me. Thanks!
73,
Dan, KC9VZV
