Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Tennessee Radio Discussion Forum
Tennessee Radio Discussion Forum - Forum for discussing Radio Information in the State of Tennessee.
Old 07-26-2014, 9:48 PM
Exclamation Metro Nashville Police & Fire
No longer receiving Nashville Police & Fire dispatch. I am using a Uniden BCD436HP. Anyone have any insight on whats going on?
Old 07-27-2014, 7:37 AM
Receiving fine here.
Check your settings again. Make sure all frequencies are programmed. Control Channel may have changed.
Relm HS200, BCD396XT, HP-1E, BCD436HP, BCD536HP, BCD325P2
Old 07-27-2014, 3:28 PM
Default Updated CC's
Same problem with Uniden but I noticed that my Pro-106 was still receiving Metro. I cross referenced the two scanner CC's and found (6) that were not listed in the RR Database for Davidson County. It is one of the following that did the trick:
851.1375
851.3875
852.5500
853.1250
856.2125
857.0375
Hope this helps out. I imagine that the RR database will be updated soon with the revised CC frequencies.
Old 07-28-2014, 8:22 PM
Ok, found the issue. Here are the current Control and Alternate control channels....
C:857.0375
A:856.4875
A:856.7125
A:857.4875
I even had to make an adjustment to my XTS5000... I have noticed that the control channel seems to change about once a month. So.. I'll keep on analyzing the system and advising of updates.
Disregard the red and blue and black... What we're looking at is the "A" or "C" in the usage column.
Old 08-04-2014, 5:53 PM
Default broken reception
I'm using my new BCD436HP and am having trouble with reception. It's broken and garbled. I've tried different antennas, including a 25' base discone. I live just 5 miles south of downtown. Is there anyone else using a 436 with any success ? If so, are there special settings I'm overlooking ? I've been using a PSR500 until metro went to phase 2. If I need to add the freqs listed above, do I need to delete any other freqs ? Do they need to be in chronological order ? SORRY so many questions, but I've been at this all day, trying different things with no success. Any help is MUCH appreciated.
BCD436HP, PSR 500, Trunktracker 3, several others
Old 08-04-2014, 6:39 PM
milf's Avatar
Careful, I CAN hear you!
OK, finally got the new CC lineup done, sorry for delays guys... And as far as I know METRO is not using TDMA yet...
APX6000XE
Old 08-05-2014, 7:55 AM
Default nashville pd cc
What is the new line up on contra
l channels ? Just bought a new bcd 436 and not receiving any metro
channels at all..I'M about fifteen miles five miles from hermitage.
Old 08-05-2014, 8:08 AM
please disregard….I got them,
Old 08-05-2014, 7:20 PM
Well i loaded all cc into my bcd 436 hp, plus all secondary frequencies . Im just not having any luck receiving the metro nashville p25 system!
Any suggestions would be appreciated.
I did receive some of the fire departments transmissions for about ten minutes and then they went dead !
No trouble with receiving Mt.Juliet!
Old 08-05-2014, 8:11 PM
Post
I'm not familiar with the 436, but I too was not receiving Metro on my GRE PSR 500 and 800 until I loaded the control channel that someone posted above, 857.0375, and then I began receiving Metro on both radios. (Monitoring from Murfreesboro.)
Old 08-05-2014, 8:24 PM
I loaded same cc frequency along with others listed..still no luck !
What antenna are you using ?
Old 08-06-2014, 6:42 AM
Post
The Radio Shack 800 MHz antenna. Also, in reviewing the previous posts in this thread, it seems that the problem may be with the Uniden scanner. For example, the poster that began this thread, (see above), was using a 436 and then later on another commented that he couldn't receive Metro on his Uniden but could on his Pro106, which I think was made by GRE before they went out of business. Just as a suggestion, maybe you could check with those two posters to see if they ever solved the problem. Also, if it is the Uniden scanner, maybe a post in the Uniden forum would help.
Old 08-06-2014, 3:51 PM
When searching in digital mode, I found 857.2625 popped up under the 443 system (Metro Davidson simulcast) which is not listed on RR database.
Old 08-06-2014, 6:18 PM
Well after entering 857.2625 metro came alive…for how long..who knows! Im not going to hold my breath! lo..lo..tnx for the info Nashmonitor. crossing my fingers.
Old 08-07-2014, 8:21 AM
ur welcome jerry. just wish I had some luck with it on my 436. Tried different antennas, drove around the area...no luck. I must not be using the right settings. I'll play with it again today for a few hours. Cheers
Old 08-07-2014, 10:20 AM
codeplug's Avatar
It appears that the simulcast site 303 has too many alternate control channels listed.
I believe the system is still Motorola, if so it should have one control channel and three alternate control channels.
The last time I decoded the system back in June 2014 these frequencies below were active as control and or alternates.
856.4875c / 856.7125a / 857.0375a / 857.4875a
For some reason on decode it was showing 851.9625 as a possible alternate control but I can't confirm.
As stated the control channels appear to change fairly often.
All three Sites are now showing TDMA Table Identifiers but it appears that they are not currently using them.
Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.00625,1 > Current Table Setting in use.
01,762.00625,0.00625,30.00000,"Confirmed",0.00625, 1
02,851.01250,0.01250,-45.00000,"Confirmed",0.01250,2 > Phase 2 TDMA Identifier - ID: 02
02,762.00625,0.01250,30.00000,"Confirmed",0.01250, 2 > Phase 2 TDMA Identifier - ID: 03
Decode Dump is showing > TDMA Sync Broadcast - *Invalid*
Under License/Call Sign WPGJ688 there are 31 freq.'s listed on the license.
I cant confirm if any of those frequencies not listed in RRDb are active on that site or not.
Emission indicator 8K70D1W was added back in Oct. 2012 to some of the freq.'s.
Not showing any current modifications for that License/Call Sign.
Old 08-07-2014, 5:04 PM
I received metro good copy since yesterday at 3 pm until 9 am this morning and it just went dead again.
how many control channels is metro allocated ? They seem to be changing control channels ever 24 hours! They must have a endless supply of control channels…this is weird! Im attempting decoding with the bcd 436 hp…
Tnx code plug …I do have your suggested control channels loaded and Im sure you're aware that the new bcd 436
is capable of decoded the phase 2 and tdma …but not much success with nashville metro!
Old 08-07-2014, 6:53 PM
milf's Avatar
As the system is undergoing multiple conversions and additions in an upcoming big changeover, its rotating through multiple CC's as changes are made. It is an Motorola ASTRO-25 system, and is fully upgrading to Phase II capability for the aforementioned changes. Hopefully soon you will all be pleasantly surprised by these changes.... It will take a bit of time afterwards for the system to fully settle down.... Just keep an eye on the CC's... and SysID.....
APX6000XE
Old 08-08-2014, 12:18 PM
codeplug's Avatar
I believe these should be the current control channels for Site 303 or at least some of them.
851.96250c / 856.48750a / 856.71250a / 857.48750a
On decode of this site these four control and alternate control channels above were shown.
Shown in numerical order, but may not be the actual control channel sequence.
856.48750 was the active control channel the last time I checked this site.
For some reason 857.03750 was also showing up on decode as an alternate control on the frequency list
but it appears it was shown incorrectly as an alternate control, I could be wrong.
857.26250 did not show up on my last decode so I canít confirm activity or use.
I have never seem more than four control or alternate control channels listed on a Motorola system.
Old 08-08-2014, 7:28 PM
milf's Avatar
Correct Motorola uses a full set of 4, though sometimes they may only have 2 or 3 active in rotation.... As changes are ongoing on the system, there will be many switches of the 4 chan sets until all switches/modifications are finalized. Once the final changes are made, we will have a pretty much locked down set of 4. As a system switches to an new CC that is not in the original set up, you will get a whole new set of 4 until the next changes happen. As new CC's pop on, I will list them as such until we get a final set of 4.. Once we have a set on and not changing for at least 2 months, we can consider it "finalized" as far as rotation unless another big change happens.... Over the last 2 weeks, the CC set up has been in flux. for one am glad its not an Harris P25 as they literally can and often do rotate through every freq.
APX6000XE
