Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Texas Radio Discussion Forum
Texas Radio Discussion Forum Forum for discussing Radio Information in the State of Texas.
  #41 (permalink)
Old 11-23-2012, 4:53 PM
Send a message via Yahoo to donhark
Most of them are on LCRA towers with the 900 MHz system.
Donald
  #42 (permalink)
Old 11-27-2012, 12:49 AM
texasemt13's Avatar
CenTex DBA
Originally Posted by NC5267 View Post
I had heard that the P25 towers were going to be on the same towers as the 900mhz ones. So I would think that there would be a second P25 tower somewhere in the Comal area
I think this is generally the case, but we're seeing much better coverage with this system, so I bet some are stand alone 700MHz sites.
John H. "Boat" Boatright
Elecraft K2; RACAL 25; Yaesu FT-7900R, FT-270; GRE PSR-500
  #43 (permalink)
Old 11-28-2012, 10:33 PM
Pro96com is hitting on these talkgroups on the Live Oak site.
12017,50,"T: 11919 DT: 11/26/12@11:12",1354145751,"11/28/2012 @ 17:35",1353949971,"11/26/2012 @ 11:12","#000000","#000000","N",8
12064,50,"T: 11919 DT: 11/26/12@7:54",1353944742,"11/26/2012 @ 09:45",1353938086,"11/26/2012 @ 07:54","#000000","#000000","N",2
12065,50,"T: 11919 DT: 11/26/12@7:55",1354006831,"11/27/2012 @ 03:00",1353938154,"11/26/2012 @ 07:55","#000000","#000000","N",1
12072,50,"T: 11919 DT: 11/26/12@7:55",1354153401,"11/28/2012 @ 19:43",1353938130,"11/26/2012 @ 07:55","#000000","#000000","N",4
12088,50,"T: 11919 DT: 11/26/12@20:44",1354127415,"11/28/2012 @ 12:30",1353984278,"11/26/2012 @ 20:44","#000000","#000000","N",4
12097,50,"T: 11919 DT: 11/26/12@7:05",1354134028,"11/28/2012 @ 14:20",1353935142,"11/26/2012 @ 07:05","#000000","#000000","N",3
Donald
  #44 (permalink)
Old 12-18-2012, 2:29 PM
Looks like Cibolo will be getting P25 radios here soon, heard some techs on TG 11 testing radios in the Cibolo area and trying to figure out which site will be their primary and which sites will be roaming. From what they were saying it was bouncing back and forth from the Live Oak tower to the New Braunfels tower more than they had thought. Cibolo is a tricky area but finally being able to roam between sites will help them out a lot. Wonder if the old vhf patch will still be up after they make the switch.
  #45 (permalink)
Old 12-18-2012, 2:47 PM
Thanks for the update. I Guess the repeater will be shut down after Cibolo moves. I will be on the look out for new Cibolo tgs.
Donald
  #46 (permalink)
Old 12-18-2012, 9:07 PM
Schertz has patched Cibolo FD to the p25 site from time to time. The TG is in the database. Other than that Cibolo PD may get a talk or ops channel but they will still be dispatched by Schertz.
  #47 (permalink)
Old 12-18-2012, 10:31 PM
The Schertz repeater on 159.1200 MHz is patch to tg 218 on the old Live Oak system and tg 12103 on the p25 system all of the time.
Donald
  #48 (permalink)
Old 12-19-2012, 4:25 PM
Yeah they do that because some of the Cibolo officers still have vhf handhelds and car radios and some have non P25 EDACS radios. I think Schertz made the jump to P25 a lot faster than Cibolo had thought they would.
  #49 (permalink)
Old 12-19-2012, 4:48 PM
The Cibolo officers that have trunk radios are school officers.
Donald
  #50 (permalink)
Old 12-19-2012, 4:54 PM
Here is my pro96com log for the kingsbury site
FileVersion:7
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 200
System Name :
WACN : 92571
Tower Number (Decimal): 10707
Tower Number (Hex) : T6B07
Tower Description : (null)
Control Capabilities : Data,Voice,Registration
Call Sign(s) :
Timestamp : Wed Dec 19 13:14:13 2012
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,769.00625,0.01250,30.00000,"Confirmed",0.00625, 1
01,851.00000,0.01250,-45.00000,"Confirmed",0.00625,1
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"00-0327","c",773.09375,"00-0327",803.09375,0,0
"00-0387","v",773.84375,"00-0387",803.84375,0,18
"00-0447","v",774.59375,"00-0000",769.00625,1,19
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
10202,"T6602",200,"00-0324",773.05625,""
10303,"T6703",200,"00-0016",769.20625,""
10404,"T6804",200,"00-0403",774.04375,""
10505,"T6905",200,"00-0016",769.20625,""
11919,"T7713",200,"01-0026",851.32500,""
Donald
  #51 (permalink)
Old 12-21-2012, 12:29 PM
The New Braunfels control channel is gone today, did a quick scan through the 700mhz band and only get a couple of the SAUA Control Channels. the Live Oak CC in the 800mhz side is working as normal. Weird thing is I am getting New Braunfels FD patch coming through on the Live Oak side.
  #52 (permalink)
Old 12-21-2012, 12:53 PM
I just ran pro96com on the New Braunfels site the other day. The last few days pro96com has found alot of new tgs on the Live Oak site. I have not heard anything on them yet.
Donald
  #53 (permalink)
Old 12-21-2012, 1:08 PM
Some Cibolo officers have the new radios, can tell from the the Radio ID's, Also heard a quick radio check on Cibolo FD TG 12111
  #54 (permalink)
Old 12-21-2012, 1:23 PM
I also heard Cibolo officers using new radios this morning. I am looking for new Cibolo tgs. The New Braunfels site is still showing up as a neighboring site for the Live Oak site. The cc is still the same. I can't hear the New Braunfels cc at this time.
Donald
  #55 (permalink)
Old 12-21-2012, 2:24 PM
Seeing key ups on 12115, 12119 and 12118.. I am sure these are Cibolo TGs they are in line with the FD TG on 12111.
And I normally get the NB site full signal but right now, nothing at all. Maybe the are working on the tower since all of the activity is on the LIve Oak site right now until NB makes the swith. I will only hear TGs on the NB site every once and awhile either random patch TGs or Live Oak primary.
  #56 (permalink)
Old 12-21-2012, 2:29 PM
Yes I am also seeing the same.
Donald
  #57 (permalink)
Old 12-21-2012, 3:37 PM
LCRA was talking on tg 11019. I think it is one of the New Braunfels Fire tgs. I also have tg 11017 and 11018.
Donald
  #58 (permalink)
Old 12-21-2012, 5:31 PM
Yeah I caught that, talking about how the NBFD VHF patch was working again and how the LCRA had to get their P25 radios to stay on the Live Oak Tower so their radio could work. Guess they are doing something with the NB Tower.
  #59 (permalink)
Old 12-21-2012, 5:48 PM
Do you know what frequency the vhf patch is using? I know that they have stopped using 154.1300 MHz.
Donald
  #60 (permalink)
Old 12-21-2012, 5:54 PM
texasemt13's Avatar
CenTex DBA
154.1300 MHz isn't obsolete yet. They've used it in all the past flood events. They're also licensed 151.0100, 151.0400, 154.3100 on the same license (KKV500). 151.0400 is the input to 154.1300, the other two I'm not sure about. Check all of those.
