Each Batallion/District has an access channel. These are used exclusively for a field unit to contact his appropriate geographical dispatcher, based on the 8 battalions. There should be no tactical operations on the D access channels. The Tac channels are for units to use on the fireground to talk to each other. A dispatcher will probably be assigned to a tac channel if it is a working fire, etc...
Hope this helps.
