Originally Posted by Cressida81
Hey, i just relocated to Rowlett and was looking to setup my old Pro-95 to listen but it looks like the pro-95 won't support the rebanding. We just bought our first house and had our first kid so money is tight. What is the cheapest trunking scanner that supports the new rebanding?
Cressida,
In the Radio Shack line, the Pro-164 will support the
Garland system, but it requires using software & the pc interface cable to enter the rebanding tables. Same with the discontinued PSR-300; GRE makes both scanners. You might find the 164 on sale, if you're patient, but the ac adapter and pc cable are extra cost items. The 300, being discontinued, might be found used, either here in the classifieds, or on eBay. It came with an adapter, but not the cable. Software is the same, and an extra cost item, for both.
GRE's replacement for the PSR-300 is the
PSR-310. You'd still need the ac adapter, or plan to keep a stock of rechargeable batteries on hand, but it can be programmed, including the custom band plan, through the keyboard. (Software is easier, though.) The
PSR-700, which has the RadioReference database loaded in it, would also work.
The current Uniden hand-held analog scanner is the
BC346XT. It comes with the ac adapter, pc cable, and FreeSCAN can be used for programming, though it can be programmed through the keyboard. Older Uniden analog scanners that would also work include the BC246T & the BR330T. Of those two, the 246T would be cheaper on the used market.
FreeSCAN works with them as well.
Please remember that just to your northwest, this
system serves Plano, Allen, Wylie, & Murphy. It's a P25 (digital) system, as is
Richardson now. Should those interest you (
Texas DPS is also digital), then you may want to consider, if not now, at a future date, a digital scanner. The
PSR-500 is GRE's current digital hand-held. Radio Shack sells what is essentially the same scanner, just with a different front panel arrangement, as the
Pro-106. While R/S often puts the 106 on sale for a little less than the normal PSR-500 price, the 500 comes with the ac adapter & pc cable. The Pro-106 does not. Software is extra (same program for either). For Uniden, the current digital handheld is the
BCD396XT. It comes with pc cable, ac adapter, and rechargeable batteries, & you can use FreeSCAN. You might find one or any of these scanners on eBay, or in the classifieds here on RadioReference.
