Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Texas Radio Discussion Forum
Texas Radio Discussion Forum Forum for discussing Radio Information in the State of Texas.
Old 01-20-2012, 02:41 PM
Default Programming LCRA
Hello all, new guy here. I am interested in getting a scanner and programming in the LCRA for Hays county so I can listen to the fire/EMS every now and then but really don't have a clue where to begin, especially with this 900mhz system. If someone could point me in the right direction for a good scanner that can pick it up and how to begin programming it that would be awesome. I appreciate any help in advance.
Old 01-22-2012, 01:04 PM
texasemt13's Avatar
CenTex DBA
js0610,
First let me welcome you to RR. I also live in Hays County, on the south side, near the Comal County line on 1102.
LCRA currently operates an EDACS 900 MHz trunking system, which is analog. Most of the older scanners will trunktrack an EDACS system in this band.
I have used a few older ones (Pro-2052, Pro-93, Pro-95, Pro-96, Pro-97) and currently use a PSR-500. You don't need anything special for this system, as long as it trunktracks an EDACS system, in the 900 MHz band.
In the future (they haven't said when yet) they're going to transition all of their public safety to a digital (P25) trunking system in the 700 MHz public safety band, and in fact they have already started the build out of this system (which is in the database as the LCRA-P25 system). I think this transition is still a ways off because all of the New Braunfels and San Marcos subscribers are still carrying analog radios.
If you have enough to spend on a new digital scanner it will receive analog and digital transmissions and would prevent you from having an obsolete scanner when LCRA does make the switch to their digital system.
Just start rattling off questions and we'll be glad to answer them.
John H. "Boat" Boatright
Elecraft K2; RACAL 25; Yaesu FT-7900R, FT-270; GRE PSR-500
