| Texas Radio Discussion Forum Forum for discussing Radio Information in the State of Texas. |
01-31-2012, 02:21 AM
McAllen Project 25 TRS
I see that the city of McAllen in Hidalgo County, has a license application before the FCC to upgrade their system to Project 25. Here is more on the FCC Web site:
FCC Application
73s
Ron
"A bank is a place where they lend you an umbrella in fair weather and ask for it back when it begins to rain." Robert Frost.
01-31-2012, 01:07 PM
Its the same frequencies they are using right now. What makes it a P25? Thought it would be using different frequencies.
BCD396T, PRO-2050, PRO-2053, PRO-97, PRO-94, PRO-83, PRO-106, and AOR AR8000
Software Scancat-lite Plus, Win-500, Arc500-Pro, and BCD396T Uniden Advanced Scanner Director
01-31-2012, 03:34 PM
Texas DB Admin
On the ULS site, select Frequencies tab; then down on the right, next to 'Define View:' click on Emission. You see [A] 8K10F1E which means they're adding P25 to the existing freq; the other code is analog. Typically, they borrow a couple of freqs from the existing system (minimum 2: 1 control and 1 voice) and set them up on the new system and test this way for awhile. When they're ready to cut over to P25 they will remove freqs from the analog system and add them to the P25 system. If they do a full cutover then they'll move all the users and freqs in one fell swoop. If they do it in groups they will move over enough freqs to cover the number of users they move over.
01-31-2012, 05:46 PM
Mc P-25
I Think Mcallen along with most hidalgo County Cities will use this TRS. And by the way is up and running..its got 24 reapeters county wide and its a TDMA P25 Phase 2? System-Fcc WPSE816 and WQLJ634
02-01-2012, 12:41 PM
TRS mean
This means we cannot monitor them with the currernt radios. What does TRS mean? I know there is not a scanner that can monitor TDMA P25 phase 2. I was thinking if I program the frequencies as conventional will I be able to listen to them. Yes or No?
02-08-2012, 01:41 AM
A new two-site system STA license has been applied for by the city of McAllen. It will be interesting to see how the existing 800 MHz frequencies play into their long-term plans. You can read more about it on the FCC Web site:
FCC Application
Supporting Letter
73s
Ron
02-08-2012, 01:45 AM
Originally Posted by al95
What does TRS mean?
TRS stands for either "Trunked Radio System," or "Trunking Radio System," whichever context is correct for the given phrasing.
73s
Ron
02-08-2012, 05:10 PM
How would I program this new system>
Mcallen will be in a new 700Mhz frequencies. How would I program this frequencies? Will it be the same way I program the 800Mhz or will there be more steps to do. Does anyone know if Brownsville,Tx is doing the same thing?
02-08-2012, 09:09 PM
CenTex DBA
For the Pro-106/win500 set them up like a normal P25 trunking system, as "P25 Auto."
John H. "Boat" Boatright
Elecraft K2; RACAL 25; Yaesu FT-7900R, FT-270; GRE PSR-500
02-09-2012, 05:24 PM
04-17-2012, 08:05 PM
Mc 700 Mhz. and 800Mhz.
In my opinion I think the City will keep the current 800Mhz. syst. for city services only while the Pd. Fire and emergency services will migrate to the 700Hmz. Trs. .....by the way I'v been unitrunking the Hidalgo County's New (4) P25 trunked sites and they are working togather with raymondville and willacy countys trs. and I'v counted 55 talk groups and growing..also they can interact with Phar'rs existing P25 ttrs....3 talkgroups so far .And the fcc application
for Hidalgo county says its temporary pending rebanding Mayb To ???
