ce2576
Hoping someone on here knows what system of frequency they have recently moved to. Throughout the 8 yrs or so that they have provided EMS service to Johnson County, they have been on the Oncor EDACS system, 2 different LTR systems, several different 400mhz UHF high band frequencies, and most recently they had been dispatching the ground medics down here on CERN Tower (464.100)
I have been scanning the 450''s up through the 480's on UHF high when I know there is an active call in the county, but I haven't heard a peep from them on any UHF 400mhz frequency.
Right now I'm at a bit of a loss as to what they are currently using and am hoping there are some other Johnson County scanner folks on here that might be able to provide an answer.
I kinda wonder if they aren't planning a move to the new 700 digital system down here? I have that system plugged into the scanner and have it set in ID SEARCH mode should any new TG's pop up.
Thanks!!
Thanks!!
