Ensnared
Today, I finally heard Temple PD via new ProVoice upgrade. I believe 09-041 is Temple PD Dispatch and 09-052 is Temple PD, channel 3 (talk). I will continue to monitor and eventually submit.
Thanks for your hard work, Temple is probably the closest PV system for me to test out my upgrade, I travel across the country on my job, so it may take me a couple of weeks to get home to test it out. My antenna sits on a 50 foot tower in Milam county, I should be able to hear Temple from home, although I've never tried listening to the Bell County public safety system, but have no trouble hearing the Temple area amateur radio systems.
Belton PD uses Provoice. Killeen IIRC still uses analog.
Most other LE traffic in Bell County is on the East, West, and Main channels. County also dispatches Belton Fire on their published talkgroups, not sure about PD.
I will be moving there for college within a week or so, ill also upgrade and start monitoring.
I am assuming you are making reference to upgrading a 436/536HP, right? I have ID search activated. Between patients, and sometimes with them in the room with the radio on low volume, I monitor the radio in Temple. But, at night, when the action happens, I am back in Waco. So, yes, I would appreciate having some much needed help.
Thanks for your response.
I just ran across your thread. I was searching for some info on Temple PD because I haven't herd anything for awhile. I still hear some fire calls toned out on Temple talkgroup thou. I live in Belton and listen them and to most of BellCo on my old RS Pro 97? triple trunking hand held. It had been in storage for several years. I dusted it off a few weeks ago, put some new batteries in it and reprogrammed the entire thing by hand with RR DB info. I use to have software and cables, etc... but they are misplaced somewhere. The following info I think is correct but not positive. I hear 200 units (Belton PD) talking in my area.
508 03-154 A Belton PD LE 3 BELTON PD/MORGAN'S POINT DISPATCH Law Talk*
509 03-155 A Belton PD LE Tac 1 BELTON PD TAC 1 Law Talk*
321 02-081 A Bel PD MAIN BELTON PD MAIN Law Dispatch*
I don't have a new scanner to monitor the new technology. any suggestions on what to upgrade too?
I'm retired and up most nights monitoring and getting my old favorite music tunes together.
I'm new to this RR thread stuff so I apologize in advance if anything is not done correctly or I'm not posting things right. any help or advice is welcomed.
