XTL/XTS5000 05 control head .cvn file
Trooper78
TN
Hello everyone ! I am new to Motorola radios. I recently was given a few Motorola radios and control heads from a friend of mine. One XTL5000 had a W7 head on it. I was also given a newer 05 control head. My question is, what .cvn file would I need to synchronize the 05 Control Head to the XTL5000 radio ? The radio has this loaded at this time.... FIRMWARE R20.50.09 DSP: R19.50.01 TUNING: R01.08.02 BOOTLOADER: R07.00.00 PSDT: R04.00.00 . I have a .cvn file ( ASTRO_25_CH_AA.cvn ), but it is not the correct one. Can anyone tell me the correct file, and would anyone have a copy they could share with me thanks !!
Trooper78
TN
Correction....I have (ASTRO_25_CH_AM.cvn) file..... If any more info is needed please let me know. Thanks !!
wgbecks
NE Wisconsin
You may not require a CH synchronization to accomplish this task. You didn't state if this is Dash Mount, or a Remote Mount application. However, suffice it to say that if you have the correct hardware pieces in place, then you should be able to migrate from the W7 to the 05 head using CPS in view of the fact that your radio on FW 20.50.09 already supports the 05 head.
Your success in this migration has to begin with interconnecting the correct flex(s), TIB,CHIB, cables per your specific configuration.
Trooper78
TN
It is a dash mount configuration as of now....
Trooper78
TN
Also the control head reads " Maintenance Mode Remote Device " then switches to " Maintenance Mode Local Device "
