10 codes and signal codes for HCSD
#1
does anyone have the signal codes (i.e. officer says "38-43, 10-8 Signal 38" or similar") for the Houston County Sheriffs Department? i have tried a few 10 codes list that i found online but they don't seem to match up. i have not been able to find any of the signal codes. any help is appreciated. their frequency is 454.625MHz.
#2
Dothan PD and Houston County share the same 10 codes and signals. 38xx is the unit number. I have tried to copy and paste them and been unsuccessful. Post an email and I will forward.
