104 FW F15's up
#1
KILLER 1 & RAGE 1 (2 Each, F15's) appear to be up this morning training in the upper NY area around 0955 hrs local. Likely will be returning to KBAF by 1100 hrs or so. Typical ATC frequencies in use: 251.1, 281.5, 379.1. Air/air 264.85, 259.9, command post 309.0.
SLAM
