ai8o
Brachiating Tetrapod
Often times while listening to The CAR-A and CAR-B HF frequencies, I hear NY ARINC Center telling aircraft "upon reaching ONGOT, contact New York Center on 126.025".
Usually these aircraft are using the track LAMER-BOREX-ONGOT.
I looked at the FAA WATRS map, and saw that the next NB mandatory reporting point is OXANA.
Leading NW from OXANA is a clear path between MOA 27 and MOA122 (AR8) that points directly from OXANA to the ECG 112.5 Beacon at Elizabeth City, North Carolina .
I call this path the "tunnel".
I never hear any aircraft on CAR-A or CAR-B after they approach ONGOT.
Question 1) Do aircraft contact the regular ZNY ARTCC on 126.025, or do they stay under NY ARINC Center control until they reach some other point?
Question 2) Do the aircraft approaching ONGOT turn and fly north on a track farther east of the MOAs, or do they fly up the tunnel to over land, and come under the control of ZDC or ZJX ARTCC?
Question 3) I see the ground transmitter for 126.025 is listed as MANTEO, so I presume it is co-located with 124.725 xmtr. Should I send in a RR submission requesting that this Xmtr be listed on the North Carolina RR page?
Question 4) I see a similar xmtr (133.575) for NY Center listed as Wilmington, North Carolina.
Is there a "tunnel" leading to Wilmington? What is its' switch over reporting point?
Question 5) I could see that there might be a RABAL-GRAMN-PERDO-??? path.
Are there other similar "tunnels" between other MOAs along the East Coast?
Question 6) At what point do aircraft leaving the US switch over from VHF to HF?
