155.640/Schenectady?
jgorman21
#1
Picking up P 25 last couple of days. Tonight I put it on PSR 500. Not sure who it is yet. NAC 293. Will listen more!
Thunderknight
Bletchley Park
#2
It might be Schenectady PD. There was talk of them going digital awhile back. If you can confirm its then, submit a database update as they are still listed as analog.
DaveNF2G
Rensselaer, NY
#4
Last I heard, Schenectady had some P25 portables that they used on regular repeater outputs. CTCSS kept the rest of the department from hearing the noise.
DaveNF2G
Rensselaer, NY
#6
This is probably SPD detectives with radios that have replaced the UHF gear they used to use. 460.350 is probably deprecated.
