160.815 Indianapolis Weds 10/26/16
Indianapolis,Indiana
#1
On Weds 10/26/16 around 10:30AM was searching the railroad frequencies and heard a repeater on 160.815 was not railroad traffic. Did a fcc database search and found a couple of active users on this frequency. Radio traffic was asking someone to meet them inside a building. Sounded like a contractor for construction with dump trucks. Signal was very loud from a Bearcat 300 about 30 feet above ground without using a outdoor antenna. Just using the pull up whip that came with the Bearcat 300. Anyone have any ideas on who this may be? Thank you.
milf
Careful, I CAN hear you!
Indianapolis, IN
#3
Considering the sheer volume of construction projects in and around the Metro INDY area.... If you can copy an tighter location, like intersections, etc... We can narrow it down.
