169.5750 P25
otrebla
If you are in the Rhinelander/Iron Mountain region give this frequency a listen. I listened friday, saturday & sunday and I wasn't able to ID the federal user.
RevGary
Senior Tropical Storm Analyst, TSRC, in Alabama
Assigned to three agencies by IRAC as a common use / shared frequency for Bureau of Land Management, National Park Service Administration and the Bureau of Reclaimation... ALL in the western states, NOT the midwest. Very curious to say the least.
Did you hear a repeater or was it simplex?
OpSec
Code 21, Status 7
Underground
It's prolly BLM up north...they are all over up there on the fed land.
otrebla
It was a repeater. I could hear a dispatcher and mobiles mention locations throughout northern wisconsin and the western U.P.
otrebla
Just back from the northwoods. It appears the frequency is used by the Department of Veterans Affairs for security at the VA Hospital in Iron Mountain and VA Clinics in northern Wisconsin and Michigan's U.P.
triryche
Marinette County, WI
I would concur.. good copy over most of Northern Marinette and sounds like security in a building like a hospital and maybe even maintenence..
