171.3125 MHz in Waterloo
bwjmackie
Ontario, Canada
There seems to be a plumbing company active on 171.3125 MHz in the Waterloo area today. I found them on Close Call.
Anyone know who is using this frequency? I couldn't find anything in TAFL.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
My guess would be you heard a mobile tx from the City of Waterloo Works Dept.
If that is the case, the true frequency would be 171.315.
What is the step size set to for VHF in your scanner?
motomeso
Ontario
Yes you are hearing the City of Kitchener Utilities department which is obviously homed on this LTR channel.
gary123
remember close call uses the default step sizes, any freq located with close call should be rounded up/down to the nearest 15 khz step before refering to TAFL.
