173.1625 New DEA in Bay Area?
Oakland_Tower
S.F. Bay Area
#1
173.1625 NAC 156 is active "in the clear" this morning. Very loud signal in Fremont...possibly up on Mt. Allison/Monutment Peak. It seems to be linked to 172.2125 as they are both active at the same time, but the .2125 is barely readable.
kma371
Global DB Admin
#2
Also hearing P25 on 173.475 NAC 156. Might be related, but coming in real weak.
Oakland_Tower
S.F. Bay Area
#3
Now I'm hearing 172.2125 very loud...as a control channel (I think). I can hear encrypted transmissions with a PL of 67.0, which seems odd.
Taxachusetts
#4
IF you are not set to P25 [using Auto] sometimes it goes analog and logs 67.0
Set that channel to P25 and you should get the correct NAC
