1998 Ram Install
Hutchinson, KS
#1
WatnNY
Knoxville, TN
#2
Why the wide space between radios if I can ask. Yoou have enough room for your leg to get to the gas pedal I take it?
Other than those two questions looks like you did a very good job! You should be proud of yourself.
Mike
Hutchinson, KS
#3
Mike
I have plans to install two external speakers between the two radios. I spent about 5 hours getting it all ran. The bracket I installed about a half inch too close to the cupholder so now that stays permanently down.
Sent from my SM-G930F using Tapatalk
