rescuecomm
I have a 2 meter wide split repeater for portable use only. The present input frequency is 147.600 mhz which is unused in our area because the 147.000 mhz repeater uses the low input (146.400 mhz). The output frequency is 145.110 mhz which is not used in our area. The problem during the last communications test was getting Yaesu radios to program the 2.490 mhz offset. It appears that the VX-170 and other units can easily do a 2.500 mhz offset, but requires a rather lengthy keystroke sequence to do the 2.490 split. No one was able to do it on the fly without their software. To remedy the situation, I have a choice of buying a new crystal for the transmitter to move it lower in frequency (145.100 mhz is easiest, but not really a bandplan frequency). The other choice is to recrystal the receiver to 147.610 mhz. Any changes need to be multiples of 50 khz which is the odd split step in the Yaseu radios. The repeater is an old Micor trunk mount conversion. Changing the transmit is easy and the repeater will see very limited on air time. Any suggestions? I am in the SERA coordination area.
Bob
Bob
