2 Pin ear piece for use with radio and ear protection simultaneusly
ronedog
I need a bit of help figuring out how to make the following work. I have a Baofeng UV5r and a UV-82. I would like to use these radios while in the outdoors with my Howard Leight ear protection ear muffs. Specifically, I want to be able to send and receive while having the radio in my pocket using the push to talk button on the ear piece wire.
The Howard Leight ear protection has a jack to receive audio input and play it through the ear protection.
I found a link to a product that I think would do the trick (see the end of my post), but it looks like it's missing the "mic" part for me to be able to speak into so I could use the radio using the push-to-talk button.
Is there another product out there that has everything I need to be able to do this? I read somewhere that kenwood 2 pin accessories could also be used by these 2 radios?
Alternatively, I'm willing to do some DIY work if it's not too involved....what I really want is the exact thing I already have with the 2 pin baofeng ear piece/mic here's a link to it: http://www.amazon.com/gp/product/B0...82 earpiece&qid=1453682988&ref_=sr_1_2&sr=8-2 but I need the ear listening piece removed and an audio jack put onto it so I can plug it into the howard leight ear muffs...is it possible to cut the earpiece end off and solder a 3.5mm audio male fitting so I could plug it into the ear protection...thus giving me the listening through the howard leight muffs as well as the push-to-talk?
Here is a link to the product that provides most of what I need, except the "mic" portion.
BTECH 2 pin accessory
Thanks in advance for your help.
So, the big issue is that if you are in an environment that a high noise level, the microphone is going to pick that up and likely wipe out your transmit audio.
Not sure if the pin spacing is the same, but we have used similar headsets at work in our co-gen plant:
Robot Check
N4GIX
Hot Springs, AR
Huh, I got the ear piece and mic accessory included in both my UV-5VR2+ radios. I don't care for them at all because the earpiece "wraps around your ear" and I find it very uncomfortable to use.
ronedog
thx for the reply. I got the same ear piece with the uv5r...can I cut off the ear piece and attach a male 3.5mm jack?
FKimble
Newnan, GA
IF i UNDERSTAND YOU CORRECTLY, THEN A SPEAKERMIKE, with a earpiece socket and a double male cable should work for you.
N4GIX
Hot Springs, AR
Yes, that is a simple matter to do if you have a soldering iron and aren't afraid to use it! :lol:
