2 Proscan questions
dave3825
Suffolk County NY
First is, in the Logging tab, in there it displays the RSSI value. Is there a way to see the RSSI value in the Recorder tab?
And second, I have a fav list with many uhf freqs that have the known dcs / pl tones programmed in. In that list, there are quite a few freqs that are set to tone search as the tones are not listed in the database. I wanted to know if there is a way in the logging tab for it to display some kind of indication that a tone was detected from the search? Any way to differentiate between a programmed tone and a tone found using tone search?
Whiskey3JMC
Chimer Inner
Out of Area 🇺🇸
I'm not seeing a way, but it does show up in History log.txt
This should show up in the tone field of the history logging tab & in History log.txt even if the tone is set to search (though I can only speak for the x36HPs & SDSx00's) You're not seeing it there?
dave3825
Suffolk County NY
Looking to see if Proscan can indicate a detected tone found from tone search to appear differently than a tone that is predefined in the scanner.
For example,
Holbrook District 1 is programmed in the scanner set to tone search.
Hauppauge Cmd / Ops is programmed in the scanner with a tone of 031.
Whiskey3JMC
Chimer Inner
Out of Area 🇺🇸
Ah, got you. Perhaps placing an asterisk before the detected tone would be useful. Bob @ProScan would this be feasible in a future release or maybe add a separate column to indicate the tone was detected from a search?
