2 radios 1 antenna
W9WSS
Retired LEO
Westmont, DuPage County, IL USA
If you are not going to transmit on the antennas, you may consider a multicoupler. If you *might* transmit, then avoid this method of multiple radios to one antenna. You will destroy the internal components of the multicoupler, and void the lifetime warranty.
IdleMonitor
The Ottawa Valley - Eastern Ontario
I would use this for another setup of just recievers only.
JayMojave
Mojave Ca
One of the problems with a coax switching two radios to one antenna, is you will anadvertenly key up the radio not connected to a antenna and might damage it. Been there done that.
Jay in the Great Mojave DEsert
While I'm not a fan of MFJ, this might be a good option:
two radios to two antenna ports. install a 50Ω dummy load on one of the antenna ports.
But, unlikely a stock CB would be damaged by transmitting without a load attached.
prcguy
I have two radio operating locations at my house for hamster radios and I share antennas between locations with a 12v coaxial relay. The relay is wired so it passes the antenna to my garage radio when my house radio is turned off and when I turn on the house radio it also powers the relay switching the antenna to the house radio. It works perfect for me and requires no thought, which I'm running low on these days.
W9WSS
Retired LEO
A few courageous hams and CB'ers have a "shack" in their garages. I guess with you being Texas, that wouldn't matter, but overnight here in the western suburbs of Chicago, it was 4 degrees! We have a heatwave, as it's now 20 at 2:00 pm.
KevinC
The big K
Super Moderator
1 point
C'mon on down to Texas in August when it's 100 degrees and 90% humidity and see how much it doesn't matter.:p
prcguy
My main house is in So Cal and my garage there is quite comfy. The garage radio in TX is used mostly by remote control so I don't have to suffer, but it was in the high 70s when I was there last week and very nice. No garage radio in MA, just one in the house that I can use remote control from anywhere and its a balmy 25deg there today.
