Well I finally had time to install my Yaesu FT-7800R in my 4Runner. It took quite a few hours to get everything installed. Running the power was the easiest. I found a rubber plug on the driver side firewall. I simply cut the rubber nipple off the black plug, and was easily able to run the positive and negative cables to the battery.
I ended up installing the main unit next to the front passenger door. I wanted it hidden, but was really limited on where to mount it. I had to take the front cubby hole door off, to mount the speaker. I mounted the faceplate onto the center console, with two small screws and 3M sticky tape. The hand mic is held on by some 3M sticky tape. I really didn't want to drill holes into the dash, so the tape will have to do for now.
The antennas were permanent mounted with two 3/4 inch NMO mounts. I used the Antennex hole saw to make the holes. Running the coax to the front of the vehicle was a bit tough, but I managed to get it. The small antenna is an Antennex Phantom, for my BCD396T scanner. The other antenna is a Comet.
In order to drill the holes in the roof, I had to take off the left rear side panel. This allowed me to pull the headliner down a bit to make sure I wasn't drilling into any roof supports.
