2006 Impalla Install
alphagamma
New Hampshire
I am sure this has been asked a thousand times but I figured someone would have a good idea, I have a 2006 impalla ltz and I am a new emt and need to install a scanner in the car, I have looked around at some of the console mount options but all of which are not possible because of the center console shifter, has anyone come up with a good idea for placement or modification of the center console to put a scanner or multiple radios in the console area?
Thanks in advance
fineshot1
NJ USA (Republic of NJ)
Use the search feature and search on "impala" (with one L) as there are way too many
threads to post on here but there is already a wealth of info on mounting equipment on
and in impala's. Most of it is pretty good info.
Also - somewhere in all that info i saw a scanner mounted in the oem center console
hidden under the arm rest door and it looked pretty slick. It was a very nice and stealthy
arrangement.
I have a 2000 Impala LS - see below a pic of an earlier install of mine. It may give you
some ideas and if not i am sure the others will. Sorry for the lousy quality pic but i am
not too good with cameras and taking pics. Good luck.....
