2007 Crown Victoria Police Car Setup
aconway
#5
I love my Crown Vic. It didn't have any of the equipment installed it when I got it. I installed it all myself. The reason I didn't buy a faceplate for this radio is because I couldn't find one for it anywhere.
Uranus
#6
Try and see if you can find a face plate for a VX2500/3200 the radio you have looks like it might be the same dimensions. I've noticed you have some electrical on the antenna connection.
Uranus
#9
The 2200 uses a totally different mounting bracket then the 25/3200 and the radio he has. From the pic of the radio it looks like it uses the same bracket as the 25/3200. If I'm correct I believe the faceplates for the consoles attach to the sides of the radio where the mounting bracket would attach too. The 2200 uses 1 screw on each side and the screws are larger in diameter then the 25/3200.
aconway
#11
I don't know who the console manufacturer is. The console came with my car, it was just sitting in the trunk when I got it from the auction. I painted it and got some new mounting hardware for it and installed it. I am happy with it even thought I don't have a face plate for it, I think it works fine for what I need. Maybe someday! Thanks for all the comments so far!
Manhattan, KS
#12
Good lookin car, well done on getting that all in!
If you want help finding what manufacturer that is pop some of those covers off and take pictures of the rail system. We can tell what kind of rail system the faceplates use to determine Havis, Jotto, Troy, etc.
