2007 Tahoe update with SDS100
03msc
Arkansas
#3
Got to believe a mobile version is coming...just have to have patience.
Looks good.
wise871
Florida
#5
Looks like a Watson on your SDS100, and is that with the stock adapter?
Looking good! I'd say you are covered :)
I’m using the Diamond RH77CA. I’m using the Uniden supplied SMA/BNC adapter with it. I used a black zip tie around it so I could hold it to remove the BNC antenna without the thing unscrewing. Uniden made the adapter so small you can’t get your fingers around it to remove a BNC antenna. I may try to find a o-ring to fit it later.
LZJSR
California
#13
Does the scanner shake around with it only being held by the mic clip holder? I bought the ProClip mount too, but the scanner shakes around too much to use it.
KE5MC
Lewisville, TX
#14
It helps when removing the BNC antenna to push into the body of the radio with your thumb and forefinger before you twist the BNC a 1/4 turn.
That pushing in takes the pressure of the spring washer inside the antenna side of the connection off the two small stubs. That makes it easier to twist off the antenna and leave the adaptor behind.
Mike
Kingman, AZ
#16
Mike
Or just get the SMA version like everyone else and avoid the signal loss from adapter.
