Hello,
I have a PSR500 and would like to setup my radio to use the multisite feature to track the conversations from tower to tower. I setup my radio with the trunking information with the closest tower and only programmed the control channels for it. I set it up for multisite and was thinking that if i roamed outside of the coverage area (which I do) than the radio would search for a new CC and use that. The radio just sits there with no signal like it is still trying to search for that one tower. What do I need to do to get the radio to roam on each tower that is in different locations? If this is in the wrong section please move accordingly?
Thanks,
Joey
I have a PSR 600....In order to receive everything on Viper using all available Control frequencies you need to set your 500 to Stationary instead of Roam...also you need to set it to scan all CC.. These can be set by doing a PGM Global and a PGM TSYS edit Viper or whatever you have called your system...My 600 recieves about 13 sites or more just from my home location and my viper stays active much of the time....remember to turn on all CC's and set it to STATIONARY. In the ROAM position it will grap the first strong available signal and stick with it until the signal falls below the low threshold setting... I have reset my thresholds to 80 high and 50 low....hope this helps...
