2010 F-150 - scanner install
#1
Got around to installing my Uniden 436. Install was fairly easy.
I bought the fender mount and a Laird antenna.
I have had great luck with a Scoshe magnetic mount that i use for my iPhone (as you can see in one of the pics)
I bought a Ram mount cradle, and using some Gorilla glue adhesive and one screw, I attached the Scoshe magnetic plate to the back of the cradle.
This allows me to easily remove the cradle from the console.
Scoshe dash mounts: https://www.amazon.com/gp/product/B00I608BJ8/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
Ram Mount cradle: https://www.amazon.com/gp/product/B001QD8Q5Q/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
I ran the coax up behind the dash and through the cubby/compartment (drilled a small hole in the back of the pocket).
The only thing I may want is to either do Aux audio to my head unit, or an external speaker.
#5
The install is slightly different now, I am using a ram mount arm and its suction cupped on the front of the center console..which allows the handheld to angle at a better angle to keep the cable from looping up like that.
ShyFlyer
Colorado
#9
I'm a big fan of the Scosche phone mounts. I'd considered a similar mount for my 436HP but was concerned the magnets would affect the reception performance.
