2010 Honda CR-V
K9GTJ
Kokomo, IN
You may remember my old 2005 Ford Ranger thread with a Uniden Scanner and Yaesu FT-8900 here. That truck became history this week when I purchased a new 2010 Honda CR-V.
I plan to install the FT-8900 and plan to use the Comet SBB15 antenna since it seems to be the best option. I want to keep 6 meter capabilities but don't need 10 meters. (We have a six meter repeater here in town is why I want to keep 6 meter capabilities.)
I am not sure what my plans are for an antenna mounting. I do garage it every day and do not wish to fold something over each time I enter and leave the garage.
I also need a scanner antenna. I assume the smaller windows on the side (near the cargo/hatch area) are passivated glass which will prohibit an thru the glass antenna.
I have some ideas but figured I would let other shoot me some ideas too.
Some important limiting factors. No holes in the roof/body. This thing has air bags everywhere so the pillars and the top along the doors plus the usual spots up front are unusable for coax, power, or control cable runs.
I also have the roof rails across the top which are on order but not shown.
Thanks in advance for any ideas.
N8IAA
Fortunately, GA
Diamond makes a motorized rack mount that will tip the antenna over without you having to get out of your vehicle. /\/\ike, the antenna he has is a bit big to 'tape' to the almost car antenna:lol:
Larry
You can put another rack mount for the scanner antenna. Don't specifically know what you monitor, so, can't really give you my guess for that.
Larry
K9GTJ
Kokomo, IN
The 6 meter triband antennas are longer than recommended for the motorized solution. I was thinking of making a custom bracket to mount on the drivers side where the drilled and tapped holes are for a hitch. Sound like an idea?
b7spectra
EMS Dispatcher
Cobb County, GA
Not tape to the antenna, but a splitter to use. Or like what is done in some U/C vehicles, mount the antenna inside the vehicle.
K9GTJ
Kokomo, IN
It's not cheap, but you could consider Stico's hidden behind the bumper VHF antenna. It covers 136-174 Mhz and you CAN transmit on it.
Click here: Sti-Co: Custom Antenna Supplier and Manufacturer: VHF Bumper
That is interesting.
However at this point I have ordered a Comet CP-5M and plan to mount it on the hatch even with the back up lights. My everyday antenna will be the Comet SBB1 which has been a good antenna. I also ordered a Comet SBB-15 which will provide me 6 meter coverage as needed.
I will rear mount the FT-8900 and also ordered a separation kit.
I will likely need to work on a better solution for 6 meters in the future.
I am unsure if I will continue with a scanner mounted in the car. I think my handheld will be fine and I can easily patch the audio into the car audio system if needed.
Hopefully I will have it mounted on Friday or Saturday.
K9GTJ
Kokomo, IN
Overall my plan looks good but the ground for six meters to get the SWR down is going to be a PIA. I have the antenna mounted and the SWR is more than 3. :(
