2011 2500 hd silverado radio install
327skidoo
North Dakota
hi all i am installing a two way radio in a 2011 chevy pickup (Something i have done many times and am very familiar with) i have always ran the power cable straight to the battery but the customer i am installing it for wants it hooked up to keyed power i was wondering if there was a place under the dash i could steal power from thanks in advanced
KC4YIN
Kinston NC
I would put a ignition switched relay in line to power it.[/QUOTE]
Yeh. That's what we did. We used the older Ford starter solonoid relay.
On the other hand, what kind of radio are we talking about installing? It may be one that has an AUTO power off mode you can program into it if that is the concern.
wg5jim
Keller, Tx
How did you end up doing the power and antenna? I'm working on my 2009 Silverado 2500HD Duramax LTZ.
n3obl
Ø
PA
im doing my first duramax. Which battery should i use.. the one on the drivers side toward front or the pass side rear near firewall
Frank
KK4LBX
Livingston, TN
duramax
If I'm not mistaking, you would need to hook to the main battery in which looks like everything else is coming off of. If it's like the Cummins I was messing with, it was like that and had a hot wire going around the front of the motor to the other battery linking it. I mean check it out little more before taking my info completely but that's what I'd do if it was me.
bikinjohn
Las Vegas, NV
Wirelessly posted (Mozilla/5.0 (iPhone; CPU iPhone OS 6_1_4 like Mac OS X) AppleWebKit/536.26 (KHTML, like Gecko) CriOS/31.0.1650.18 Mobile/10B350 Safari/8536.25)
The battery on the pass side is the only battery on most Chevy trucks/SUVs. That would lead me to believe the battery on the driver side is the aux battery, but since it's a diesel I would assume they are connected in parallel constantly with a thick gauge wire so it really wouldn't matter.
brennank
Twin Cities MN
You guys should really look through the GM Upfitters manuals. Lots of information in there and many places to tie in for power. Many are easier and lead to a cleaner install then running to the battery.
GM UPFITTER - Body Builder Manuals
Use these all the time for my Duramax. The Upfitters manual and Helms service manuals are invaluable if you do any of your own work.
On your Duramax the batteries are connected together. It does not matter what battery you use.
