2014 ford f150
dmb201
HI all, I have a 2014 ford F150 and need to know where i can get Ignition Sence from in side the vehicle.
I currently have 2 Vertex EVX5400's Installed that support it and am looking at installing another radio that will also support it but i have no clue where i can get it form.
If all you are doing is running the ignition sense circuits for 3 radios, you might be OK without the relay.
Might be worth testing one of the radios to see how much current it draws on the ignition sense circuit, it's probably really low. If it's high enough that you think you need a relay, I'd recommend looking at a Chargeguard, Lind timer, or similar product. It'll do the same function, plus give you some additional controls, like having the radios stay on for x amount of time after ignition shuts off, battery low voltage disconnect, etc.
