2016 Jeep Wrangler installation
Wyandotte Michigan
#1
I haven't posted a vehicle install post since 2007 when I outfitted my 2007 Ford Focus with radios, maybe it's somewhere in the archive worth revisiting some day. I bought a used Jeep Wrangler and a couple weekends ago installed some of the same equipment I removed from my Focus.
Working on the Jeep was easy, probably one of the easiest vehicles to work on since there is so much aftermarket stuff out there.
I've included pictures of the old and the new, some of my ideas on the new vehicle were brought to me by these forums- thanks for the inspiration!
Radios:
Kenwood NX-700HK
Pyramid SVR-200 mobile repeater.
That's it- the SVR is controlled via panel button on the NX700- so no additional wiring was needed.
Antennas: PCTEL VHF Half-wave
Maxrad UHF low-profile antenna (a Laird is shown, but it was changed).
So far it works pretty well for not having a ground plane.
Wyandotte Michigan
#2
The old... The Focus install was a new one for me, I wanted to do it better than the 97 Escort I had prior, so I planned it out carefully. The CDM1250 was upgraded to a CDM1550 and then ultimately in 2011 was changed out for the Kenwood NX700 that I reused in my new vehicle... All radios were mounted on the white shelf-board and adhered to the trunk wall with Velcro. Good stuff!
