2019 VHF Low Band Logs
Dispatrick
Bergen County, New Jersey
#1
Starting the list early this year!
Bergen County NJ
opening between approx 10:20 and 11:30
37.040 127.3 Smyth County VA Sheriff
42.940 173.8 Either NC or MO, open mic received for about 2:30 seconds
46.080 151.4 Bartow County GA Fire Disp (The EARLIEST I've ever heard this station. usually only hear it on the hottest of summer days.)
I started using ProScan about a month ago after a coworker showed me how to use it. Now I can "Set it and forget it" and come home at the end of the day and see my logs! Saves a ton of time.
East Cobb County GA
#3
Bartow County is about to go live with a 700mhz Phase 2 System Feb 15th...the fact they've had low band this long is an anomaly down here as most everything is 700/800 mhz trunked or VHF high band for many many years...end of a low band era if they cut it off for sure.
trashman43
Kentucky DB Admin...
Kentucky
#4
Monitored from Central Ky using a Pro 197, Win500 and a 6 meter Ringo Ranger on 2-7-19 and 2-8-19
30.000 PL 150.0 Roughneck
30.300 PL 150.0 convoy
30.325 PL 150.0 unk US.mil
30.450 PL 150.0 Ft. Hood
30.500 PL 150.0 Outlaw Ops
30.525 PL 150.0 unk US.mil
30.550 PL 150.0 Helos
32.050 PL 150.0 Misery base
32.500 PL 150.0 Outlaw
30.600 PL 150.0 unk US.mil
32.650 PL 150.0 unk US.mil
33.600 PL 150.0 Helos
32.900 PL 150.0 convoy
34.150 PL 150.0 RC
34.200 PL 150.0 Camp Bullis RC
34.500 PL 150.0 Ft. Sill RC
36.500 PL 150.0 Ft. Carson
38.350 PL 150.0 Ft. Carson
38.900 PL 150.0 Ft. Knox
41.000 PL 150.0 Ft. Bragg
41.200 PL 150.0 VAARNG
41.500 csq Helos
47.000 PL 150.0 Helos
Dispatrick
#6
Ideally warmer months like summer and spring, but occasionally I'll get a some hits during other parts of the year, like my previous post of some early February logs. last December MOHP was coming in for about 10 minutes and faded very fast.
trashman43
Kentucky
#8
Monitored from Central Ky using a Pro 197, Win500 and a 6 meter Ringo Ranger on 2-16-19 and 3-3-19
32.100 PL 150.0 unk US.mil
32.350 PL 150.0 Helos A-A
34.150 PL 150.0 unk range control
40.150 PL 150.0 Ft. Campbell (possible)
41.500 PL 150.0 Helos
49.950 PL 150.0 Helos
Springhill,La.
#10
I don't understand how you are doing this. Is it all skip? I live in Louisiana about 40 miles from Barksdale afb and I have never heard anything in the low band..
Central, NC
#11
Yes it is skip... it is mostly prevalent in the summer months, but it can happen any time of year. I once hear a solid 30+ minute opening from here in NC into PA and MD. I was getting very strong signals on an indoor, tiny whip antenna and that was on Christmas Eve. The openings may be weak and only last for a few minutes or you may have stations coming in crystal-clear from several states away for hours. It's just a matter of catching the opening at the right time.
