2180/3180 MDC 1200
Markscan
New Jersey
I recently received a 2180 and a 3180. This is my first time with Kenwood's. I love how easy the software is, and had both radios programmed quickly. However, I can't seem to get them to transmit MDC 1200 id's. They both receive id's fine, but will not transmit. Any ideas?
Thanks as usual for any help.
Arizona
I don't have the software in front of me right now only my phone, but where you have been entering the channel data there is a button at the bottom that says channel edit. Or you should be able to double click the channel number. It will then open the data for that channel. You must select either pre, post or both to transmit your MDC1200 data for that channel.
TelcomJunkie
Southern Central Valley, CA
You also have to set up the choice of FleetSync or MDC1200 under the model information box. After that, setup your MDC info under Edit->MDC1200 and make sure that Optional Features->Common Page 3 you have changed the PTT ID Type to MDC1200. Finally, for each channel that you want to have PTT ID you have to select either BOT or EOT under the advanced channel edit page.
Also, this is assuming you have a firmware revision and high enough version of KPG-89 to support MDC.
Markscan
New Jersey
Yup. I didn't see the channel edit button. Everything is working now. As always, Thank You!
