246 charging port
#1
anyone ever have a problem with the charging port on the 246 t. recently i noticed that my 246 is not holding a charge. i replaced the batteries and got the same result. i finally found that when my charging cable is inserted, it is not charging the batteries. as i am sitting here it is plugged in, and beeping. anyone have any advice or info about how to fix it.
VA
#2
you could get a seperate charger for the batteries, lots of folks say they work better ...
can you check the tip of the ac adapter with a dmm to see if there is voltage?
