255.550 FM - Spanish - 2:21 CST Up
FrankJ
Euclid, Ohio
I've been picking up some strong transmissions on this frequency as well, although it's a Eastern European language, not Spanish. Using my PRO-43 and Diamond RH-77CA.
Frank
Northeast Ohio
SkyFoxx
Front Royal
That frequency is used by Brazilian pirates and speaking Portuguese. They are on some others as well but 255.55 seems to be the one with the most traffic.
ryangassxx
Banned
Inside of your head
I was hearing it this morning... These guys hijack a military satellite to make these transmissions.. All it takes is a strong directional TX on the input freq of "296.550", and they can basically use one of the United States military satellites as their own private space repeater... Pretty crazy.. Speculation is that these are drug dealers discussing details for trafficking drugs..
KG9NZ
Westerville, OH
How can these signals be so strong?
Satellite is presumably geosynchronous so it is going to be at least 36,000 km away even if it was right overhead.
Path loss (dB) is 32.5 + 20*log10(MHz) + 20*log10(km)
So in this case 32.5 + 20*log10(256) + 20*log10(36000)
= 172dB
Now I don't know what the ERP of the satellite is but lets take a guess and say its 10 watts on that particular frequency. Thats 40dBm. Therefore, received signal will be somewhere around -172 + 40 = -132dBm. Assume antenna has 3dB gain over isotropic. That's still -129dBm. That's 0.08uV. How many receivers have this kind of sensitivity? Yet I hear people describing receiving these with just the whip antenna on their receiver. I don't understand this. Certainly with a good gain antenna reception should not be a problem. But with just a whip antenna or even a discone? Unless my assumption of the satellite's ERP on that frequency is way low.
Frank KG9NZ
ryangassxx
Banned
Inside of your head
= 172dB
Frank KG9NZ
Well I can hear it really well with my MVT-7100, but with any of my other radios, nothing but static.. I think you do need to have a somewhat above average radio in terms of sensitivity..
prcguy
The older UHF transponders (Gapfiller) had an EIRP of around 23dBW and newer satellites are more. Even with some of the earliest UHF satellites, 23dBW and a 5dBi gain antenna on the ground would give around .45uv at the receiver assuming no other losses. I routinely pick up the newer satellites weakly with the stock rubber antenna on my PRO-43 and with a Maldol AL-500H they come in quite good.
I should post a pic of my UHF satcom mobile antenna, it brings in the pirates full quieting.
prcguy
= 172dB
Frank KG9NZ
chrismol1
P25 TruCking!
How are these people doing that?
Talking on satcoms?
with a 10 watt radio?
chrismol1
P25 TruCking!
Sure. I can hit the AO-51 amateur satellite with my 5 watt HT, no problem. Ain't no obstructions straight up into space!
yeh,
"i've heard that most of the signal goes into the sky"
Didnt really know if you could really hit a sat com with a regular HT and a "sticky duckie" antenna
All new thing now, wow
KG9NZ
Westerville, OH
Talking on satcoms?
Most of the amateur satellites are much closer (say 1/10 of the distance) than the military satellites. That means their signal is going to be about 100 times as strong as the military satellites (if they are on the same frequency and running the same power). It's no problem to hear the amateur satellites, even with just a scanner. You can go to www.amsat.org and get a schedule of satellite passes based on your location. Pick a satellite that has FM voice, tune your scanner to the frequency at pass time, and you should hear them no problem. I had questioned how the military satellites which are so much further away could be heard. But someone explained that these have an effective radiated power of around 200 watts, which would explain why they appear so strong (the ham satellites and low orbit weather satellites usually run only a few watts). As far as reception in the other direction (military satellites receiving ground transmissions) that would be somewhat less impressive since I'm sure they have a receiver that is much more sensitive than the average scanner.
Frank
prcguy
The typical UHF satcom terminal is capable of 20 watts or so but you can communicate just fine down to about 5 watts with the most basic 5dBi gain antenna that folds up and fits in your shirt pocket. Some military users have had success communicating through the UHF satellites with the 5w MBITR or newer PRC-152 walki-talki.
prcguy
Talking on satcoms?
immelmen
Talking on satcoms?
they are most likely using 20watt Alinco DR-235 FM mobiles with the mod done to open up the transmit to 300mhz that can be found on the web.
that is why the 255.55 is the most herd freq. its input is the lowest and one of the few that is below 300 where it can be reached by the easily modded Alinco(available to anyone with $200 at your local HRO or AES).
there are pics at uhf-satcom.com of modded DR-235s in action on UFO satellites. there is even a pic of two alincos in the mod process.
C
comsec1
Guest
elizibeth, nj busted
on 2/26/08 the fcc busted someone using 296.55 in elizibeth nj. call sign was n2kbj. probably a real good chance it was spanish from that area. check fcc web page for enforcment.
Cowthief
Texas
SatComm Comms.
Hello.
A LOT of 220 radios can do the military SatComs.
It is easy enough to where even I have done it.
It is the NTIA, and not the FCC, that gets to deal with you.
In my case I had IDed myself and said who I was and why I was doing it.
No biggie, and I wound up with some excellent contacts from within the military.
But, this was all done before 9/11, and things have changed.
grem467
Houston, TX
must have been the UHF FPP Satcom spectra.
i think the only contacts you would make as a result of bootlegging on the sats, would be to your arse in the pen.
