2nd car battery question
quant
Hi All
For a CB, can I run power from an additional battery stored in the trunk instead of running from the main battery?
Thanks..
mjthomas59
The simple answer would be yes..... but why would you 1) have 2nd battery in your trunk, 2) need to run the cb off of it, 3) how do you keep the battery in the trunk charged, and 4) how do you talk on the cb if you are driving and it is in the trunk?
Just wonderin!
902
Downsouthsomewhere
Some vehicles have a similar setup. My Suburban has two batteries; both fit under the hood.
Thing is that CB radios don't draw that much power. Are you sure you need a second battery?
obijohn
Just wonderin!
The only reason that I can see why he would want to run his CB radio off a battery in the trunk is for a linear amplifier!
Geeze, a modern CB radio might draw 3 amps on transmit. A big linear amp will draw anything between 20 and 200 amps.
Be sure to run a LARGE 12 volt wire back there.
P.S. Don't forget to fuse it at the alternator!
gmclam
Fair Oaks, CA
You can also isolate the two battery circuits with 2 diodes, one to each battery. The diodes would need to be something like 100 amp and mounted in heat sinks. As far as fuses are concerned, there really should be two fuses; one on each end of that long wire going to the trunk. One fuse as close to the battery in the trunk as possible, and one from the feedpoint under the hood. That way if the insulation on that wire rubs off or melts there will be a fuse to kill power from either source. Otherwise keep a fire extinguisher handy.
kb2vxa
Banned
Point Pleasant Beach, N.J.
The trunk is a dangerous place to put a battery. Check them out at the next "key down" and you'll see what they do with battery banks, locomotive alternators and gazillion watt amplifiers. You'll learn what real idiots are if you survive the RF exposure and don't come out looking like the videos I've seen, all scrambled.
DickH
WP4MZR said:
Is the second battery hard wired to the fuel pump?
And where is the 2nd fuel tank ?
WileyClarkson
2nd battery
I run a second battery on my truck that is mounted in my toolbox. It is a deep cycle battery that I isolate from the starting battery by an ignition controlled high current relay mounted under the hood. The charging wire from the battery is a #8 stranded copper wire with high current spade fuses on both ends. All of my electronic equipment runs off the deep cycle battery and can be left on when I am not in the truck without fear of killing my starting battery. The equipment included an FT-857d HF/VHF/UHH transceiver, CB, GPS, Vehicle rear view video, radar detector, two 12vdc to 120 ac 500 watt inverters (one under the front seat and one in the toolbox, and Nokia cell phone vehicle mounting system. It also powers a winch mounted in the tool box that allows remote control of the tool box lid for lowering the antennas and opening the toolbox. I have been running this arrangement for 2+ years.
http://www.clarksons.org/AmateurRadio/my_mobile_installation.htm (photos of installation)
WA5OTR
Ch1ronTL34
WA5OTR
Very cool install!
You should post that link in the "Pictures of your Shack" forum, I'm sure many more people would love to see your install. Do you have any pictures of the outside of your truck/antennas?
MrRevesz
Mid-Coast Maine
mdulrich said:
Somebody needs to let the car manufacturers know this.
Mike
+1... there's a reason why they put it in the trunk... if he puts it in the trunk in its on enclosed box, then there shouldn't be any harm done... learn some facts
WileyClarkson
2nd battery
"For a CB, can I run power from an additional battery stored in the trunk instead of running from the main battery?"
If you are going to run a 2nd battery in your sedan trunk, I would give carefull thought to using a sealed battery instead of a standard style battery with refillable cells. While I don't think there is much to worry about with a trunk mounted battery, there could be the possibility of fumes from a charging non-sealed battery that could get into the passenger compartment if the seal between the trunk and the passenger area were not very tight.
Just a thought.
Wiley
WA5OTR
Just_Me
Banned
Just a thought.
Wiley
WA5OTR
The "Fumes" I would worry about are the hydrogen and oxygen.
And I would worry that they do not leak out, not that they do leak out.
If you are overcharging to the point you get other fumes, you have a whole orther problem.
iMONITOR
Silent Key
S.E. Michigan
If you ever have a car fire, having a battery in the trunk could null and void your car insurance coverage.
enine
I have one in my truck as well. a 120A surepower isolatorto keep them isolated even when charging, its basically two diodes in a package.
My reason for using the second, isolated battery is so I can run my CB and camping lights ans such off of it for long periods of time without worrying about draining the starting battery.
scanfan03
Houston, Texas
Tell that to BMW who puts their batteries in the trunk from the factory!
