Having an antenna meant to cover the spectrum you want to monitor will make a big difference. Something that actually passes with good return loss or low swr. Having good feed line can make an even bigger difference on weak signals, if that matters to you. I compared 60+' of LMR-400 to the same length of FSJ2-50 3/8" superflex hardline for an event using the same model antennas (JTB3) at the same vertical height, it made a huge difference in received signal quality. The FG's are good base antennas, installed many of them, but what they market as the frequency coverage is about what they cover in an acceptable return loss/swr, the 3db gain models are a bit worse when sweeping them compared to the unity gain model. Your putting this on a scanner, are you going to use it to receive frequencies outside of the usable range of the antenna?
