I was wondering if I'd be able to hear anything on those old lowband freqs. So I put radio into custom search, connected an old Antron-99 cb antenna, and I can hear Norwich Fire (Ct) all the way here in Cranston (RI) Thats about 37.5 miles. Also hearing many other stations (fire, rescue) out in Connecticut. The ground around new england is not very conductive like in Kansas, lots of rocks! I realize the cb antenna is far from 30-50 mhz resonance and I am losing some signal. The antenna was cut to work on upper portion of 10 meters. I looked all over for a specific 30-50 mhz base antenna but nothing out there. I could make a simple vertical dipole but no way to hang it and get it up vertical and high enough. I also have a Diamond Discone but even with its top vertical element, the cb antenna is probably better. Anyone have different ideas? A cheap commercial antenna?
