K7MFC mobile shack: 2013 F-150 Lariat 4x4
K7MFC
WRAA720
Phx, AZ
I've been piecing together my mobile shack since purchasing my current truck about a year ago. I have everything finally done (j/k - I know it's never "done"), so here's a quick post to share my temporarily complete install. This post is especially for the Ford guys out there wondering about installing roof antenna mounts on their truck equipped with a sun roof. Antenna placement will be somewhat limited with a sunroof, but it does not present any real complications during the install process. Hopefully this post can answer some of the questions I had regarding radio installs in an F-150.
First - the truck: 2013 Ford F-150 Lariat 4x4, 3.5 EcoBoost. I purchased this truck about a year ago, and it's running strong with over 100k miles on the clock. This truck is my daily driver to the office job, but it does truck stuff too!
Next - the radios (from top to bottom):
Uniden BCD996P2 - I'm usually listening to Arizona DPS, local PDs, Phoenix & Mesa fire dispatch, and lots of other agencies/systems. Local news comms have been of interest lately too - they don't keep hush hush on the radio about incidents.
Kenwood TK-8180 (UHF - GMRS) - I'm mainly active on GMRS while in my truck, and I'm usually on the Arizona GMRS Repeater Club's 550 repeater. Daily traffic and weather nets for your commute - check us out!
Kenwood TM-281A (2m) - This radio is primarily for off-roading and back country comms. The 2m band is popular with Jeep/4x4 folks, and there is lots of activity out in the Arizona mountains or desert. Plenty of 2m repeaters on high peaks throughout the state with lots of people listening makes this an important communication tool when I'm camping well beyond cell phone service. Around town I'll usually monitor 146.52 and chat occasionally.
My F-150 is the Lariat trim, and Ford likes to use the center console shifters in these and higher trims. This significantly limits options when considering a radio install, and my only realistic option was to use the center console under the arm rest. This is far from ideal - it places the radios far out of the driver's normal field of vision, and operating any controls requires taking your eyes way off the road. Ideally, I pull off the road and park to use any radio controls that aren't just a single button press.
However, this installation configuration does offer one benefit that is important to my install - it keeps the radios out of sight. The theme of my F-150 install is to be a bit "stealth" or low key, and not stick out like a sore thumb or otherwise attract attention to myself as a result of the radios. When the center console arm rest is closed, no radios are visible from outside or inside the truck, and there is nothing to entice any potential thieves.
Let's start from the beginning! To power the radios, I ran 10ga wire (with a 30A inline fuse) from the battery and chassis ground through the firewall and up through the center console. This gen F-150 has a rubber grommet on the driver's side firewall with a nipple that can be cut off and wire fed through, making running the power from the battery and coax from the front fender mount antenna very easy. This pic I found on F150forum.com shows it better than the photo I took:
Power is run to a Blue Sea Systems fuse block and each radio has its own fused circuit:
To secure the radios, I made a mounting rack from some 3/4" plywood and some 1" pine:
I attached the legs to each radio, then the legs are attached to the base with some bolts and wingnuts. I slide the base into the center console like this:
And then I'm able to drop the radios onto the base, then slide in the bolts and tighten the wingnuts. The radios are secure and the base fits snugly in the center console storage area. Here is the completed install showing the full length center console:
Operating the radios obviously requires keeping the arm rest up, which is another pretty major drawback:
This is something I may address in the future. I would ideally like to have a custom console cover made which would be removable so it can be out of the way completely when I have the radios on.
Next up - the antennas. No install thread would be complete without some antenna pics, so here's what my roof looks like now:
On the driver's side is a Laird QWB450-796 1/4 wave UHF antenna for the TK-8180 (GMRS) and on the passenger side is a Laird QWB144 1/4 wave VHF antenna for the TM-281A. The scanner antenna is a Larsen 150/450/800 on the front driver's side fender. All antennas were purchased from The Antenna Farm:
For the roof antennas, I used two Tram 1251 NMO mounts from The Antenna Farm:
To drill the roof antenna mount holes, I used a Laird X-ACT 3/4" hole saw I purchased form ProComm in Phoenix, AZ:
As I mentioned above, the sun roof on the truck significantly limits antenna placement. With the sun roof fully open, I was able to place both antennas 12" from the rear of the roof to clear everything. Not ideal, but there is just about enough ground plane and it should work OK. Holes marked and masked - measure twice, cut once!
I put down a towel as a protective layer above the headliner when it was dropped down in order to catch all the mess from drilling and sanding. I used gorilla tape to keep the coax from flopping around off road, and ran both cables behind the rear passenger side airbag, down the rear pillar and under the door trim up to the center console.
The fender antenna mount is a Larsen NMO L bracket fender mount for Fords, which I also purchased from The Antenna Farm. I sanded, primed, and painted it black to match the truck:
All antennas are black to keep with the low key look. They are nearly invisible at a distance, blending into the background or the black color of the truck itself. Here's a few more shots of the truck and antennas:
Misc progress shots:
K7MFC
WRAA720
Phx, AZ
I have a few backup radios in the truck as well. I keep a Midland 75-822 CB radio hidden in the center console. CB is still pretty popular with 4x4 folks and it comes in handy from time to time on the dirt roads. I have it paired with a Wilson Lil Wil mag mount antenna I keep stashed under the rear seat. It's actually a pretty decent CB setup and I can get out a few miles reliably, which is about as good as one can expect from a cheap CB.
And I also keep a cheapo Baofeng UV-5R in the glove box just in case. (No pic necessary, everyone has one of these...)
Another important piece of radio tech I consider part of my mobile shack is the factory Ford SYNC/SiriusXM receiver. Satellite radio operates in the 2.3 GHz section of the S band, and in addition to the music, sports, and news channels offered, up to date traffic and weather incident data is also available. SiriusXM also provides weather and navigation data for aircraft and marine subscribers as well.
Here is the first iteration of the install shortly after buying the truck, just a single Motorola CDM1250 for GMRS:
03msc
RF is RF
The Natural State
Excellent install. Well done. I'm a fan of Kenwood radios so that makes me like it that much more.
With the console shifter in those trucks, that makes it difficult to find a place for radios. I see what you mean about the downside being having to have the console open. That would bother me, too, but the positive side is, obviously, that they can be easily hidden.
And, always great to see properly installed antennas on a vehicle. I have that fender mount from AntennaFarm for my Silverado and that tri-bander antenna. Great mounts and antenna.
K7MFC
WRAA720
Phx, AZ
Looks Great Matt!
Thanks, Chris! I have to thank you for the tip about laying down a protective layer on top of the headliner. Drilling and sanding made a nasty mess, and cleaning it up would have been very difficult otherwise.
allend
Long Beach, CA
Yes you have a sweet setup. Those Kenwood TM-281 radios are the bomb. They transmit at full power at 65 watts. Nice heat sync and none of those cheap cooling fans.
Great radio for the price.
K7MFC
WRAA720
Phx, AZ
The TM-281A is definitely a great bang for the buck. HRO always has these on sale, and I think I walked out the door with one for $130 on sale. GMRS is where I'm most active on UHF, so I didn't really need a dual band 2m/70cm. This radio is exactly what I need for a 4x4/camping radio.
K7MFC
WRAA720
Phx, AZ
Looks good.
Have you considered adding external speakers so you can hear them with the armrest down?
That's definitely on the to-do list. I have a couple extra speakers from the install in my old truck and I'm trying to figure out where I would want to mount them. There is not a lot of extra room in the footwells and along the sides of the center console in the F-150. I think my best option is on the backside of the center console, facing the rear seat. A ceiling-mounted speaker is another option I'm considering.
Even without the radios in the center console, it really helps the audio.
Not sure about the F150's, but on my 2018 F350, there's a bunch of room behind the am/fm radio head. I was able to put a full size Motorola speaker behind mine. Probably could have fit 3 smaller ones if I wanted.
Thanks for your detailed posts. It really is useful for others to see how it's done. I had a 2011 F150, XLT, so it was a bit easier to install in.
K7MFC
WRAA720
Phx, AZ
Absolutely. This post is intended to be a resource for other F-150 owners in addition to showcasing my work. The internet, including the RadioReference forums, was extremely helpful with planning and executing this install.
I hope this post finds others out there who are looking for information to help plan their own projects.
BlackSheepDue
Naples, ME
I plan on buying a 2015 F-150 Lariat in the coming months and I would like your imput; It will have a BCD996P2, a BCD536HP and either a XPR5550 or APX6500 remote head. My thought is to put the scanners in the center console and put the remote head forward of the gear shifter. Since the truck will have a full sun/moon roof, the 3 antennas will likely end up on a back-rack. My idea for the center console was to remove the cover and put the scanners sideways against the far side of the console from the driver. I was then going to get an arm rest like you see on full Harris or Jotto desk center consoles. The center console will be similar to my father’s Tahoe;
N9JIG
Sheriff
Moderator
Far NW Valley
On one of my prior installs into the center console I just removed the screws holding the hinge. I could then just pop off the lid when needed and put it back in place when parked.
I might steal your idea if I end up with the F250 I have been scoping out, just have to figure out if it will fit my garage or not.
K7MFC
WRAA720
Phx, AZ
I was considering this as well. It seems like a decent low-tech solution for the moment. Having the arm rest up limits how far back my right arm can be and can make reaching the last radio a bit difficult.
Using a headache rack for your antenna mounts is an option, but you do need to realize that it makes for a lousy ground plane.
Placing them on the roof is a better solution.
If you absolutely are against drilling holes, then make sure you get half wave antennas or an antenna that doesn't need a ground plane to work.
I've got a headache rack on my F350, however I mounted the VHF antenna in the center of the cab roof.
