38 LSB QSO:
iamjimmy86
Ontario, Canada
Greetings & salutations to all out here on RadioReference. I've got a Cobra 148GTL that I've had for quite a few years that I've wanting to try out on SSB. Now I know CB use isn't anywhere it used to be, but, if there is anyone out there that is interested in trying out a little SSB on Channel 38, I'll be making out a call around 9pm EST tonight (August 25, 2016) and tomorrow evening around 7:00pm EST. To narrow down my QTH I'm along the shore of Lake Ontario in Durham Region.
Feel free to send me a hello if you are on-air, if not, well it wouldn't be the first time I just sat there talking to myself ;-)
That's all for now,
I'm gone.
IdleMonitor
The Ottawa Valley - Eastern Ontario
Along the shore line like that I'd imagine ya gotta be able to make some contacts from Toronto and across the lake. You have a whole lake of openess with no obstructions. There should be some stations to contact somewhere.
You didn't mention however if you are operating mobile or base though.
iamjimmy86
Ontario, Canada
My apologies, it is set up as a base connected to a Wilson 1000 trunk mount whip. Thank you for the reply, so far no contacts but I plan to keep trying. Someone out there I'm sure still uses SSB CB for chats much like the Amatuer Radio nets that are held daily or weekly.
kc8kek
LSB
We use 38 LSB quite a bit in Ohio just on the other side of the lake from you. Lots of local and ground wave QSOs and ragchews. I have an A99 with a ground plane at the house, and a Uniden 980 in the car with a 102" whip (cause why not?) that I chat with almost every day on my commute.
Not sure how things are up in CA, but down here we still get quite a bit of use. If you listen between 38 and 42, lots of UK contacts, especially in the summer.
You might consider putting a ground plane on your antenna, or putting together a simple dipole. I've had good luck with both.
Enjoy
TheSpaceMann
The band has been relatively quiet for the last few days. Just wait for a band opening, and you'll be surprised at how much activity is on 38 LSB! :)
k8krh
How long are your ground plane radials on the antenna <A99> I might add a few with a ring around the bottom section below the antenna its self and to a connect to fence post on each side...
DOCTOR/795
Nutes
Ohio
Shout Ohio from Southern Ohio
That's all for now,
I'm gone.
Let me know if you try again. Give time and channel and I will listen up for you here in Southern Ohio.
Nutes
Ohio
Did not hear you
Sorry man.....I did not hear you. I switched on as soon as you posted on the 2nd.
SnowWalker
Rossland, BC
Listening for you
I tuned in on LSB 38 at the times you mentioned, but no noise from your end. Will keep my ears open.
Snow Walker: Rossland BC
SnowWalker
Rossland, BC
Not valid. I have chatted with Ten., Texas & California on my CB this past week. When the skip is good, anything can happen. Another factor, I live near the top of a mountain and have an unobstructed view towards the east & south.
iamjimmy86
Ontario, Canada
Wow there's been a bit of activity on this thread, my apologies folks I haven't checked on here for a little while. Time permitting I'll give it a go maybe on Wednesday evening. Anytime between 8-9. I'll check in every 15 minutes on the dot. One night, not on SSB but regular AM, I made a contact with a gentleman in Chicago. Would like to make use of the CB it's too bad not a lot of people up here use CB much anymore left alone the sidebands.
Just out of curiosity, has any one made use of USB? If so, does it compare favourably for QSO's?
iamjimmy86
Ontario, Canada
What the heck, I've got the radio on, sending out a hello every 5 minutes for the next 30. Feel free to say hello if you hear anyone me out: "hello on 38 lower side band, this is Mr. Radio Man. Checking in on the 5, if you're alive and well don't be shy"
TheSpaceMann
I bet if you built yourself a nice 11 meter ground plane, you'd be getting a lot more contacts! :)
iamjimmy86
Ontario, Canada
Thanks for the tip! I'll have to try it sometime or rig up a dipole. Seems to be a dying thing CB, which is a shame because it's free, doesn't require too much know how unlike amateur radio, but I'll keep giving it a go. Eventually there has to be a hello coming out of the speaker!
IdleMonitor
Skip the dipole, if you've got the space do so, spend a few dollars and get yourself an affordable Sirio Tornadio 27 from DNJ Radio
Sirio Tornado 27 27 - 30 Mhz Tunable Base Antenna, DNJ Radio
I got it while it was on sale last year for cheaper then what it is now, but this antenna seriously will do the trick for you. You may not think many people use the CB anymore, but there is still people out there, just gotta find them.
iamjimmy86
Ontario, Canada
That's a nice antenna but unfortunately a base antenna is out of my realm right now. I usually just stick to the mobile antennas as I've had fairly good luck in the past. The QSO I made with the gentleman in Chicago was using the Wilson antenna I mention previously in the thread horizontally in a North/South position. Not ideal but you're limited when you can only place the antenna in the garage. I used to have an antenna mounted to my steel fence post with a clamp but never had much luck with that.
SnowWalker
Rossland, BC
Some truckers still do respond if you are on the road. I have a sign on the back window of the Canopy of my Ford Ranger and some will give me a call now and then. Most truckers have taken the stance that a 4 wheeler is a pain in the *** and beneath their dignity to respond to. When I was a highway cowboy I rarely ignored a friendly chat with anyone on the road.
I am just getting my CB up and running and occasionally hook into CBers in the mid to southern US. You just have to be patient. I've been listening for you Jimmy, but no skip over the Great Lakes as of yet. It will happen eventually.
By the way......... I have a 20' antenna on my roof and use my Galaxy DX959 SSB mobile radio as my base radio. It's not high end as some guys in here; however, the radio does get out there.
iamjimmy86
Ontario, Canada
I'm the same way, if I have the radio on I'll try and send a hello if I hear a voice but it's mostly just people cursing and complaining 98% of the time in my area. It's more recently I hooked the radio back up to try a stab a SSB again. But I'll keep at it, like I said eventually there will be a voice on the other end. I haven't experienced any skip lately but I know it comes and goes.
