SDS200 Screen Flicker
Theo
New Port Richey, FL
2 days old the whole screen is Flickering! Mainly left side of full screen. Replaced SD card with brand new one still Flickering!!! Anybody else?
escortz28
Powell, Ohio
Hi.
Haven't observed personally or heard via a previous post. Is it flickering all of the time when powered on or just under certain operations? What happens when power cycled?
Theo
New Port Richey, FL
Hi.
Intermittently flickers left half of screen just started. Powered down unplugged still does it. turn off and on with nob also. Purchased from ScannerMaster.
UnidenSupport
Uniden Representative
Wisconsin
our warranty does not cover replacements, replacements would be handled through the retailer.
iMONITOR
Silent Key
S.E. Michigan
[source]
Scanner Master
Why buy from us and not some faceless online Mega-Store
Hassle-free, guaranteed satisfaction that your scanner purchase will meet your needs for your location.
"Maybe you'll pay a little more for the service, but you'll get a scanner that works for you and you'll have no problems with returns (within 30 days) should you decide the radio isn't right for you."
Here is why to buy from us and not a faceless online Mega-Store
ArtU
Well from my video, that is the low end of the screen problems but hope and change is on the way.. I hope...
I lowered my display backlight settings.. that only lowers the problem. Cant see as well but if you hold it up to your face 2 feet away its still there. But to be true it is better than at full display brightness, except that is what I need it to be....
Now , its related to CPU load and pre-fetch to memory banks in my guess, just as the low level noise is in audio following the same pattern; this is disregarded vibration noise in speakers that is out of scope for this detail.
I adjusted my backlight dimmer levels per several suggestions..Yea Now I need to hold the scanner radio , yes its a radio close to my face to see the flicker if nothing is happening on the scanner.
Here is what I keep seeing in what seems some load condition even from 4 feet way with lowered dimmer levels; Lock the sds200 radio into a dept or Channel, then when your other scanners show they are receiving items on the same scan lists you have programmed but you have it locked on a dept or channel .. the screen lines get really busy of artifacts...
The first tests did not have other scanners on at all, but today it looks like when the scanner is fighting to hold your talk group, the screen gets really full of lines...
